Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-24-2011, 06:25 PM
crazyduetoiowa crazyduetoiowa is offline
Send a message via AIM to crazyduetoiowa Send a message via Yahoo to crazyduetoiowa
01 overheating
My friend has a 01 3.4 with 130k. Its been overheating and loosing coolent. We tried bleeding the system but all that cam out was smoke. It is not moving coolent through the engine... Is this a bad water pump?
Old 01-28-2011, 10:01 PM
roadrunner2 roadrunner2 is offline
Re: 01 overheating
Do not drive this van until a thorough inspection has been done.
Sounds like a blown head or intake manifold gasket.
Look closely for coolant leaks.
Does the oil have a pale brown color?
Check the bottom of the oil filler cap to see.
Once the coolant has seeped into the oil it doesn't take long to strip the lubricant from the crankshaft bearings and journals.
The problem with doing nothing is not knowing when you're finished.
Overheating...overheating...overheating... 92 Firebird Camaro Discussions 13 09-08-2006 12:16 PM
'92 dynasty...overheating...OVERHEATING yooperfly General Discussion 8 07-24-2005 11:04 PM
overheating, not overheating racandbb Caravan | Voyager 0 06-23-2004 08:59 PM
89 Cherokee overheating...and overheating... frakkis Cherokee 6 05-02-2004 12:54 AM
truck overheating but gauges do not indicate overheating wucus Explorer | Explorer Sport Trac 1 10-24-2003 05:04 PM
