Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 01-23-2011, 06:43 PM
Rickpatbrown Rickpatbrown is offline
Need Timing Belt Replaced -Can I handle it?
Hey there,
My girlfriend has a 2000 CR-V. I think that its the SE. She has 145,000 miles on it and has done no maintenance besides changing the oil and air filter according to Jiffy Lube's wims. I had to replace her front rotors and brakes and went ahead and purchased the Haynes for her car. Changed the spark plugs and and wires while I was getting dirty. Her gaps in the old plugs were about 0.09 inches and looked a little ashy (hot engine?). I also think that the engine is burning oil because I only filled two quarts with the old oil and put 4 quarts in.
Any comments on the above??
My question is as stated in the subject. Is replacing the timing belt something that I can do competently?
My mechanical knowledge is limited. It has become a hobby in the past 3 months out of neccesity, in that I replaced the lower intake manifold gasket of my 99 Buick Regal. I'm pretty careful about how I go about doing things and I follow directions well.
Old 01-23-2011, 10:13 PM
BullShifter's Avatar
Re: Need Timing Belt Replaced -Can I handle it?
If you can do a lower intake gasket on a 3.8L I'm sure you can do a T/belt. Being a DOHC makes it a bit more difficult than a SOHC or a V6. A manual will make things a lot easier. Besides lining up all the timing marks and getting the new belt on, taking out the crank bolt is the hardest thing. Even with a impact some times the bolts wont crack loose. We have a special Honda crank holder and use a jack handle on a breaker bar to break them loose.
If you do the job get the parts from Honda! You should replace the following:
Timing belt
Assy. drive belts(3)
Water pump
Valve cover gasket & tube seal
Coolant
It's a good idea to adjust the valves while the valve cover is off. Other things to consider cap/rotor(Honda parts), fuel filter, trans fluid(Honda stuff whether it's manual or auto), rear diif fluid if it's AWD(Honda stuff Dual Pump fluid) Cabin air filter, brake fluid.
Old 01-24-2011, 11:00 AM
How long do you think it will take to do the timing belt? It took me almost 30 hours to do the LIM gasket. I'm sure I could do the gasket in 15 or so if I had to do it again.
She appears to be having some transmission problems as well. The car doesn't get moving when you accelerate from a stop, especially when you are stopped going up a hill. The engine revs, but the tires don't move. I suggested taking it to a trans shop. Am I right in saying that she should NOT get a trans flush? Being that she has never had the trans serviced, I've read that this can cause serious problems.
Old 01-24-2011, 10:19 PM
If I remember right the labor time is 5 hrs on the t/belt. I'm not sure how long it would actually take you being your first time. It doesn't take me long but I've done many, have all the tools, and a lift.
Once a Honda has trans issues changing the fluid by any method isn't going to help long term. It might help short term. OMG, never service? That thing should get a drain and fill every 30K! Sounds like an unmaintained vehicle.
Old 01-24-2011, 10:42 PM
When she told her Mom I was doing a tune up, her mom replied "Who even does that these days?" -I don't blame my girlfriend. She was never taught any better.
Quite frankly, I'm surprised the car is still running. We just took it on a 600 mile round trip to the mountains. I was nervous the whole ride.
I wonder if it's even worth me changing the timing belt if her trans is going.
99 Villager Timing belt replacement celica92gt Villager 2 08-22-2010 11:32 PM
99 Ranger 4 cyl Timing Belt Replacement and now it won't start. Brih Ranger | Courier 7 12-26-2009 11:39 PM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
99 replaced serpentine-need timing belt??? belzbubba22 Beetle - New/New Beetle Convertible 1 01-21-2006 11:28 AM
I Need Timing Belt Replacement! kk168168 Off-Topic 4 03-17-2004 11:22 AM
