Old 01-22-2011, 06:14 PM
brocsbar brocsbar is offline
many codes missing bank 1
98 blazer 176k miles got codes 131 o2 sensor both are new bank 1s1 and b2s1 b1s1 shows no activity (they are bosch) sometimes runs ok but some times falls on its face code 300 mult misfire it is missing on #1 #3 #5 quite a bit (got new cap rotor wires. also code 404 EGR 719-TCC , 1133 and 1381. where to start? naturally im a guy doesn't want to spend much
Old 01-22-2011, 06:45 PM
82Stang 82Stang is offline
Re: many codes missing bank 1
Getting a code for O2 sensor doesn't necessarily mean an O2 sensor. Sometimes it means 'look upstream'. As in, to the upper intake and surrounding sensors and components and vacuum. Could be a faulty EGR valve or IAC etc. Blazers are also notorious for fuel line leaks in the intake, they are in my 1993.
Multiple misfire, if you have new cap/rotor and wires, it could be a bad coil. Or suspect wiring.
I'd do the EGR first, used because new is $$, get a used one from a U-pullit or boneyard to try. Might make it run better.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 01-22-2011, 09:52 PM
what would make the whole bank miss? plus something must be going on with the o2 cause it doesn't hardly cycle on the scope
Old 01-23-2011, 01:11 AM
viggy58 viggy58 is offline
clogged exhaust? collapsed valve? mixed up firing order on the cap? did you use a/c delco cap and rotor?
clear codes, then post back with the exact order they show up.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 01-23-2011, 12:47 PM
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Rodney Dangerfield
Old 01-23-2011, 01:21 PM
Someone else put on a cap rotor wire o2s plugs and already tried to fix to no avail so im not sure what they used but from my xperience most people (not myself as I put the good stuff on my stuff) go cheap I will post back in a few days what I find.
Old 01-23-2011, 01:38 PM
I used to use the 'good' stuff myself, but with the lack of quality of parts these days, I save my money and go cheap as long as all things are equal.
Rodney Dangerfield
Old 01-23-2011, 08:11 PM
old_master's Avatar
Advisor/Moderator
As mentioned, low fuel pressure can cause O2 sensor DTC's along with a host of others. Quick easy test is to check fuel pressure and leakdown. Takes about 15 minutes and tells you immediately if there's a problem. Key ON, engine OFF, fuel pump running: Pressure must be 60PSI to 66PSI and must remain above 55PSI for 3 to 5 minutes after the fuel pump shuts off.
You have to know how it works,
to figure out why it doesn't.
Old 01-24-2011, 04:05 PM
hopefully ill get the blaz back later in the week and ill def do leakdown and get vacuum readings...im thinking intake...and i got a used EGR to try
Eng lite on. Code P0430. Bank 2. alotech Crown Victoria 1 11-16-2006 08:40 AM
Error Code 0171 - bank too lean louisherndon 4Runner/GX470 1 05-03-2006 01:37 PM
Code 1537 Bank 1 IMRC question katman96 Windstar 4 11-28-2005 09:29 AM
Code P0172 Bank 1 Running Rich wiseowl LS/LW 0 10-05-2005 12:18 PM
Obd Code 172-bank 1 Too Rich... mskrisd Grand AM 2 05-24-2004 01:45 AM
