Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-15-2006, 10:43 PM
alotech alotech is offline
Eng lite on. Code P0430. Bank 2.
Engine light came on. Stopped and had it checked. Showed P0430, Catalyst below threshold. Any suggestions? 99 CVPI 4.6L 116000 miles? Need anything else, let me know. Thanks in advance.
Old 11-16-2006, 07:40 AM
reekor reekor is offline
Re: Eng lite on. Code P0430. Bank 2.
Try cleaning the Mass AIr Flow sensor with carb cleaner or brake cleaner. Do you happen to have a K&N air filter? Also cheack for any exhaust leaks.
If none of that works hook up a scan tool and see what the O2 sensors are doing on bank 2. Compare up stream and down stream switch rate. The downstream O2 sensor should switch alot slower then the upstream O2 sensor. If the up stream and down stream switch rate is about the same replace the bank 2 (passenger side) catalytic converter.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
