Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 01-20-2011, 10:52 PM
Springman59 Springman59 is offline
Trouble reconnecting TV cable
Just replaced the head on my 96 Beretta. Am putting everything back together & cannot get the the throttle plate to close because there isn't enough slack in the cable . These are the same parts I took off to do the job. Nothing different. Any help would be appreciated.
Old 01-21-2011, 07:42 AM
snshddog snshddog is offline
Re: Trouble reconnecting TV cable
The TV cable will not hold the throttle open. Must be a problem with the throttle cable. What engine is it? The 2.2 can do it with the cables reversed, when you try and step on the pedal does it open the throttle? I know it sounds silly. With the 3.1 I have seen a bent cable bracket do it. May have bent the bracket when it was off, i have done that once. no idea why but it was bent slightly when i put one together.
how can I open tailgate when cables were not put back correctly kimm5 General Discussion 2 07-10-2010 07:24 PM
2000 SEL 3.8l Battery Cable Hot !! Nox Windstar 2 06-12-2010 01:06 AM
1985 Caprice leaks at speedometer cable Jeffesong Caprice 6 08-23-2009 11:55 PM
2005 Wrangler shift cable linkage DrRadar Wrangler 1 04-14-2009 12:24 PM
trouble codes danielgast46 F Series 6 04-06-2009 08:06 AM
