Old 01-19-2011, 09:05 AM
03lxblue 03lxblue is offline
Windstar trans- any techs> know if
well it finally happened, 118000 miles The front pump or TQ let go. Happened in my driveway so.
Typical no foward or reverse.
Van has been great since I bought it new. never a sign of trans trouble.
My question is this to the guys who have done them.
Who should I get the TQ from?
Can you slide it out to the driver side enough just to replace TQ if you lower the Crossmember? thinking flat rate here
Is there any other tricks to pulling unit out?
for any help
Old 01-19-2011, 10:00 AM
mark_gober mark_gober is offline
Re: Windstar trans- any techs> know if
Not to scare you off or anything, but I replaced the tranny in my 2000 Windstar and it was a bear of a job. I suspended the engine from above with an engine hoist, and disconnected the subframe. I realize that you aren't completely replacing the tranny, so you could probably have some success lowering the drivers side of the subframe and sliding the transmission down.
Good luck.
Mark
Old 01-19-2011, 06:43 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Hello,
welcome to the forum!
I don't think there is enough space to remove the torque converter. As Mark mentioned it is a hard job and the best way is to disconnect the subframe.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 01-19-2011, 07:16 PM
Thanks for the info guys,
I have built many hotrods over the years and a few frame off restos. I asked a ford tech and he gave me the factory service manual print out. It looks prettystraight foward. I will wrap a Load strap around the Engine and support it with a Engine hoist. HE says 98% of the time when they go like this it is only the Torque Converter.
So will give it a shot this week. When you said it was hard what was the worst part? What is your Mechanical repair history? I ask because I have been sweating doing this alone! Thanks
Old 01-19-2011, 08:25 PM
wiswind wiswind is offline
You might want to look into a alldatadiy subscription also.
That is a online version of the factory repair manual, plus all the TSB's (Technical Service Bulletins).
It is a access from under the vehicle type of job.
If you separate the transmission from the motor, you might read up on how easy it is to replace the rear shaft seal on the motor and the input shaft seal on the tranny, I'm too lazy right now to look it up......but if it is easy.....I would change those.
Of course, as you have a experienced mechanic to talk to.......pick his brain for any tips he can offer, as that will be far more help than you will get from a manual.
I DO know that there is a small metal shield that goes over the opening......slides up in between the motor and transmission.
When the tranny was replaced on my '96, they did not tighten the screws for that....and it made a nasty rattle noise.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 01-19-2011, 09:11 PM
The hard part was pulling the subframe and all associated attached stuff (brakes etc.) off. I used 6 ton jack stands just to get the vehicle high enough to lower the subframe enough that the tranny and subframe could be removed. It was a good 20" off of the ground (thats my estimate, I didn't measure)
The entire subframe is pretty large and cumbersome to lower with a standard hydraulic floor jack. Not too heavy, but just too large. Once its out, it's gotta go back in EXACTLY the same spot because if not, you're alignment will be off. (Although admittedly, your alignment will probably be off anyway because of all of the stuff you have to disconnect.) It would be an easier job on a lift, but who's got one of those?
As I remember it, there was one bolt that is extremely deep in there and it too me literally like 48" of socket extension to get a socket on it. It was on the lower side of the engine near the plate that Wiswind refers to.
On the Wiswind note, I second his recommendation of getting an Alldata subscription. I got it before I did mine and it was very helpful. (Although it makes mention of tools that you almost certainly do not have (bars that go from strut tower to strut tower to hold the engine in place, etc.) All in all, it was extremely helpful to have my Alldata subscription. It was well worth the $16 I paid for it. Actually now that I'm a year or two into it, I just have the 5 year subscription, its only $24.
As far as my repair history goes, I've replaced a clutch in a Ford Probe (horrible job also, because it was Front Wheel Drive) I've replaced many clutches in rear wheel drive vehicles and countless general automobile repair tasks (alternators, camshafts, steering gears, etc.) About the only thing I've never done was an attempted transmission overhaul. And frankly, if I never do that, I'd be cool with it. I replaced the entire transmission by myself. I did have a spare vehicle so I wasn't quite as rushed, but it was still about a 3 day job. If you worked constantly, you could probably do it in a long day or over the course of two days.
One last thing. I'd hate for you to pull the torque converter and then it doesn't fix the problem. Whats the likelihood of getting the tranny scanned by a tranny shop. I'm not doubting you, but I don't read too much about torque converters on Windstars just dying.
Good luck,
Mark
Old 01-20-2011, 12:01 PM
Off_Timing Off_Timing is offline
I knew several people who own Windstars. None of us have ever had a problem with the torque converter.
In my wife's 2000 Windstar, the reactive hub went south. That was last summer, about 120,000km
Old 01-20-2011, 06:44 PM
olopezm's Avatar
You have good information on the replacement from wiswind and Mark so you're in good hands!.
About my car experience... well I'm not an expert and most of the work I've done all by myself in my cars ranges from simple to intermediate stuff: water pumps, steering pumps, brake pads, shock absorbers and struts, fuel pumps, plugs, wires, radiators, pulleys, vacuum leaks electrical problems and sensors.
When I used to work with my father and my brother before they died we pulled the engine and transmission of different cars:
1985 Ford Econoline 150 (Engine rebuilt, new rings, etc...)
198x Chevrolet Century (Engine rebuilt)
1988 Buick Century "El Dorado" (Special Edition for Mexico, engine rebuilt)
1992 buick century (Fixed some oil leaks, cleaned engine compartment and rebuilt the transmission along with a new torque converter).
1997 Pontiac GP (Pulled the whole engine too along with the transmission when the differential somehow got screwed...)
2000 Ford Windstar (Engine rebuilt two times after it overheated twice :S because of a cooling problems, also transmission rebuilt and new torque converter when it started to shudder)
So in theory "I have experience" (or at least I should) in rebuilding engines and transmissions (my father taught us), but I've never done one all by myself... I'm more experienced with engines but when it comes to transmissions I only know very basic things and some troubleshooting but am kinda afraid of not assembling it back properly LOL.
Best regards,
Oscar.
Old 01-21-2011, 06:41 PM
Well I will have it apart on tuesday and see if the splines are shot in the TQ.
Several transmision guys I have spoke to said it is most likly the problem. They end up replacing the whole unit because they do not want any problems after they charge someone 1200. in labor to drop the trans. Labor rate here is $100. per hour in most shops and dealerships $120. So for a couple days laying on the shop floor and $250 dollars in parts what the worst that happens??
Old 01-21-2011, 07:01 PM
Several transmision guys I have spoke to said it is most likly the problem. They end up replacing the whole unit because they do not want any problems after they charge someone 1200. in labor to drop the trans. Labor rate here is $100. per hour in most shops and dealerships $120. So for a couple days laying on the shop floor and $250 dollars in parts what the worst that happens?? I must say I have a 11. second drag car that sits unused and I miss my Windstar even more..
Also just was given 2 ford windstar shop manuals and it seems straight forward to do, Any problems with exhaust bolts? Also did axles come out of hubs easy?
Was thinking I may only pull drivers side axle since I will be lowering unit and not removing it from under van??
My exhaust bolts came right out. (Although, to avoid any real problems, you really outta soak 'em in penetrating oil now and every day until you get to it.) Axles came right out also. I had more problem getting to slide back into the hubs than getting them out, but even that isn't all that difficult.
I do recommend just lowering the drivers side, but you'll almost certainly have to loosen the passengers side to get it to drop low enough. They are fairly long bolts so you should be fine. I've seen posts of other people purchasing long pieces of all thread, nuts and washers. They remove the bolts one at a time and place the all thread in there. That way they can lower the subframe much lower than would be possible with the factory bolts. It sounds like you know your way around a shop, so you'll be fine.
Keep us posted on whether or not the TQ fixes your problem.
Mark
Old 01-23-2011, 01:20 PM
Well quick update..
Got the van in the garage today and disconnected return line from cooler to trans. Started up van and no ATF came out of trans. So I am feeling a little better that the Converter splines are shot since the pump is not pumping fluid. Will start teardown monday morning after it has time to warm up in there
Old 01-24-2011, 01:15 PM
joeuser742 joeuser742 is offline
Well quick update..
That sounds like a broken pump shaft. I've heard that this is common. I think that all you should need to do is remove the valvebody, replace the broken shaft, and change the fluid. (You do not need to remove the trans to remove the valvebody)
Old 01-24-2011, 01:41 PM
tempfixit tempfixit is offline
Doesn't the oil pump shaft go thru the torque converter which is attached to the flywheel (flexplate) which turns the oil pump input shaft, so you would have to remove tranny and torque converter to replace oil pump?
Old 01-24-2011, 02:50 PM
Yup, the pump shaft goes through the torque converter. I noticed this when I changed my valvebody. I thought that the shaft pulls right out once the valvebody is out.
The valvebody will come out by pulling the cover and removing the mount.
Old 01-28-2011, 07:16 PM
OK update...
As of today I have about 6 hours into this and I have the trans out. With all this snow I have been plowing I have not had time to work on this.
Well The torque converter splines are worn away. The input shaft is fine and spins nice and can hear the pump sucking . So i will pick up converter on monday from dealer. When you look at it you can see it was a poor design. Shaft is about 1/2 in dia. and looks like in only enters the converter splines about 1/4 of an inch. by the wear line in the shaft. The magnet in the pan was thick with metal dust from splines wearing away for 100k miles. no chips or other pieces in pan so I am hoping for a nice $350.00 dollar repair plus my time. Will let you know what happens next week after I install unit. Hope it is fixed since I am holding out for a new designed Flex next year.
2000 Windstar LX, how to know if equiped with load levelling Ed_Strong Windstar 2 11-28-2008 04:09 PM
any body know any thing about engine vacumme djwho83 Non Specific 4 05-30-2008 04:45 PM
Any one know of any tracks to race in TX? x_act_o Drag Racing 15 03-14-2006 07:32 PM
Any one know any small mods for first Gen Probe? 1989ProbeGT Probe 6 02-11-2004 01:59 PM
any one know any thing about motor swaps? hoezay04 Engineering/ Technical 2 12-01-2003 11:20 AM
