Old 01-18-2011, 02:54 PM
thecackster's Avatar
thecackster thecackster is offline
Send a message via MSN to thecackster
Exclamation 97' Silverado timing issue
Okay lets just say that I'm fed up with my truck at this point. 97 Silverado 350.
The Story:
I parked it about 4 months ago due to a gasket leaking antifreeze. Dad and a friend decided to help me out so I didn't have to take it in. We pull both heads, dipped them, and clean them. Replace the lifters that seem worn, replace all other gaskets for valve covers ect...Also replaced some of the rocker arms. but in the process Dad gets pneumonia and is down for about a month. It remained covered for this time under the car port, but was very very cold sub zero temps. Now that everything has been put back together we had a hell of a time getting it to start in the first place, once we seemed to get it started it was rough but it ran. Took the distributer out to try and get it right on, and hasn't started since.
I have read in the book and from many online places that TDC and #1 but I saw on another forum that it should be on #8... Can someone plz help me out. We hooked it up to a computer and the code was cam shaft positioning error or something of the sort, so I got a new sensor.... Not sure if this is the case.
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 01-18-2011, 04:52 PM
777stickman 777stickman is offline
Re: 97' Silverado timing issue
With #1 piston at TDC on compression stroke the rotor needs to point to the #8 on the dist housing not to the #1 plug wire. Once that is set and the motor is running you'll need to set the base timing (cam retard or cam offset) with a high end scan tool that can access these settings. Base timing needs to be 0 +/- 2 degs at 1500 to 2000 rpm.
Hope this helps get you back on track.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-18-2011, 05:35 PM
Thanks mate! I hope I can get it now!
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 01-19-2011, 06:48 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
The Story:
http://files.automotiveforums.com/ga...hp?photo=51302
As 777stickman said.
And remember there is 2 TDC one compression and one exhaust.
Make sure it is on TDC compression.
You can remove no 1 spark plug and hold finger over hole to feel for compression stroke.
MT
Old 01-19-2011, 07:33 AM
Blue Bowtie's Avatar
Registered Offender
Remember to position the distributor thus:
A meter will work fine. The scan tool only displays what the sensors and PCM are telling it. You can learn what the PCM is looking at before the PCM knows it by using a meter.
You can try to manually position the crank so that the CKP is triggered, then set the distributor so that the interruptor (half cup) is just starting to cover the CMP. As long as the crank sensor triggers a couple milliseconds before the CMP triggers the PCM will stupidly accept the position as "perfect" #1 firing position. It still times from the crank sensor, so the cam sensor isn't all that critical. It's very similar to the old Ford system in that regard. What sucks is when the distributor was factory assembled so that the rotor position is not optimally aligned with the terminals in the cap when the CMP interruptor signals the cam sensor. I've seen a couple of them so bad that it looked like Bosch made them.
Can't put gas in my 06 Silverado ajdesigns Silverado 9 06-01-2010 02:16 PM
2000 Chevy Silverado 4x4 tranny issue nymike Silverado 3 03-05-2010 08:31 PM
97' Z71 Brake issue (HELP) thecackster C/K 3 12-22-2008 11:31 AM
97' AC clutch issues Netking03 Ranger | Courier 1 07-14-2007 10:50 PM
Tags
chevy , distributor , siverado
