Old 01-16-2011, 06:41 PM
reefgeorge reefgeorge is offline
2002 Blazer AC compressor
Does my vehicle have the HT-6 compressor? What are the prefered replacement brands and which ones should I stay away from? Have the "belly leaks" been solved on the OEM version?
Some of my choices:
Generic
Autotrust
Denso
Four seasons
Delphi
Spectra
AC Delco
Thanks,
George
Old 01-17-2011, 12:54 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2002 Blazer AC compressor
Some of my choices:
Generic
Autotrust
Denso
Four seasons
Delphi
Spectra
AC Delco
Thanks,
George
Brand new over rebuilt.
Delphi and Ac is good brands.
Parts books show HT-6.
But as always match up with old part.
MT
Old 01-19-2011, 02:08 PM
laxman21's Avatar
laxman21 laxman21 is offline
Get a Sanden.
THe HT6 are prone to Belly leaks. Guess what, they never fixed the problem.
I bought my last on from here:
http://cgi.ebay.com/ebaymotors/96-97...item1e5c77139f
http://cgi.ebay.com/ebaymotors/NEW-C...Q5fAccessories
http://www.acsource.com/sandenclonef...ompressor.aspx
Don't buy the cheap knock of Chinese sandens either.
With the sandens you need a slightly longer serpentine belt. But I read that you can swap on your old clutch and keep the same belt.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 06-16-2012, 11:03 AM
The clutch finally went on the old compressor so I replaced it with a new AC Delco plus a new accumulator and orifice tube. Recovered, evacuated and charged to the factory level and replaced the serpentine belt. Car cools great, all pressures and temps are good. The car is running hot at idle with the compressor engaged but fine at speed. How do I determine if the load on the engine from the compressor is excessive? Is this just a case of a new tighter compressor stressing a marginal cooling system at idle or something else. Prior to the repair work the engine temps were perfect at all rpms with or without AC.
BTW, new radiator at 110,000 miles, new coolant and cap at 160,000 miles, heater core bypassed at 160,000 miles. I have been losing coolant for 50,000 miles with no obvious source so I presume its the intake manifold issue.
Thanks,
George
2002 Blazer, 4 dr, 2wd, 199K miles
2003 Rav4, 4 cyl, 239K miles
2012 Mailibu, 4 cyl, LTZ, 85K miles
Old 06-16-2012, 05:09 PM
Update:
During the HVAC repaair I failed to notice that the coolant loss is accelerating and the level had dropped in the radiator. It is topped off and at least for now the temp at idle looks good.
What are the top reasons for coolant loss with no obvious source?
Thanks,
George
Old 06-18-2012, 09:22 PM
old_master's Avatar
Advisor/Moderator
A cooling system pressure test will help locate the leak. Lower intake manifold gasket leaks are very common on this engine. Front and rear corners of the engine where the intake, head and block all come together is a common place. Felpro has an improved design gasket set, part # is MS98002T. If clean up is done properly, bolts are torqued to proper spec and proper tightening sequence is followed, they will not leak.
You have to know how it works,
to figure out why it doesn't.
How to tell if I have keyless entry 2002 Blazer LS sadlerb_98 General Discussion 26 01-25-2013 01:34 PM
Performance Parts for 2002 Blazer ls Jandreau Problem Diagnosis 2 04-12-2009 05:28 PM
2002 AC compressor not pumping freezer65 Windstar 5 05-18-2008 06:29 PM
2002 Blazer.. Check Engine Light!!! Bridget327 Blazer 6 06-12-2004 09:48 PM
Add keyless entry to 2002 Blazer? cobra1 Blazer 2 04-05-2003 10:03 PM
