Old 02-24-2003, 12:49 PM
Bridget327 Bridget327 is offline
2002 Blazer.. Check Engine Light!!!
My 2002 Blazer with only 7000 miles had the check engine light come on and stay on.. does anyone know why this is? I have heard they are "service reminders", but I hate to take a chance. I buy new cars so I don't have to take off work.. this is frusterating. Any help is appreciated.
Old 02-24-2003, 12:54 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Usually the check engine light indicates a malfunction with the on board engine electrical and emission system. Once quick area to check is make sure the fuel cap is on tight. This has been known to cause a code and the SES light to come on and is fairly common. At any rate the vehicle is still under warranty so you should incur no charges for having the dealer check it out.
Good luck John
Old 02-25-2003, 11:15 AM
custmguru's Avatar
custmguru custmguru is offline
the fuel cap has happened to me once. luckily i knew to tighten it down and restart it and it was fine...
Old 06-08-2004, 09:49 AM
satch1967 satch1967 is offline
Re: 2002 Blazer.. Check Engine Light!!!
How do you trun off the ses light that that would help
Old 06-10-2004, 10:15 PM
price111 price111 is offline
Disconnecting the battery for about 20 minutes will clear the ECM. However, if you don't fix the "problem," the SES light will just come back on. Autozone scans for free.
Old 06-11-2004, 09:43 AM
tmcgraw77 tmcgraw77 is offline
Send a message via AIM to tmcgraw77
I also have a Nissan Maxima (2002) and every time I put gas in it if I don't twist the cap on tight enough to hear it click EVERY time the engine light comes on. So now I know to cap the lid tightly. And, once you tighten the cap it doesn't register right away and make the check engine light go off immediately. Sometimes it takes awhile.
Old 06-12-2004, 08:48 PM
tom3 tom3 is offline
Our 01 did this at about the same mileage. Bad EGR valve, expensive little rascal, thank goodness for the warranty. Even if the light goes out, they can still read the "code" and fix the problem.
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
