Old 01-11-2011, 08:02 AM
kingcamus kingcamus is offline
Exclamation serpentine wears out fast
i have had the 2004 alero for a year and half and put three belts on.....the belts start the chirp early on then eventually squeal constant non stop.....i have checked the idler pulleys with a stethoscope and no grinding....alternator is free so is tensioner i have replaced water pump as i thought that was problem as there was slight play....i dont know what else to look at??? any help would be great thanks
Old 01-13-2011, 05:47 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: serpentine wears out fast
Is this a 3400 or a 2200?
Look for fluids getting onto the belt causing it to slip. Also work the tensioner back and forth and make sure that it moves only laterally, and not in and out when you move it back and forth.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-13-2011, 07:23 PM
I did check for fluid and can't find any although I do not have a good view of the crank I had alreadyt worked the tensioner and it is fine and it is a 3400
Front Shocks Wearing Out FAST!!!! Cruize Blazer 5 08-04-2010 06:55 PM
new timing belt wearing very fast. sg.sam Rodeo | Passport | MU 7 01-21-2009 11:28 AM
Brake pads wearing out fast???? Help asinla04 General Discussions 2 03-29-2004 11:21 PM
Inner-Brake Pad Wearing Down Fast! ewang9394 Accord/TSX/Accord Hybrid 3 08-28-2003 11:43 PM
Tags
alero , belt , noise , squealing
