Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 01-09-2011, 09:10 PM
lwhistler lwhistler is offline
1999 Venture - replacing serpentine belt?
1999 Venture with air - Replacing Serpentine Belt.
Can I do this from the top? I had a quick look and it sure does look like a tough job, not much working room, Any tips? I assume a 3/8 ratchet is all I need. Thanks
Old 01-10-2011, 07:30 PM
lesterl's Avatar
lesterl lesterl is offline
Re: 1999 Venture - replacing serpentine belt?
3/8" ratchet, and a minute of time, pretty easy from the top, I would suggest removing the wiper arm plastic cover to make it easier to see/ install. Piece of cake..... Good luck!
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 01-10-2011, 08:29 PM
danielsatur danielsatur is offline
You can borrow a 3/8'' serpentine belt tool for a small deposit at any local Auto parts store.
Old 01-11-2011, 03:23 PM
Ok thanks for the replies ........ I will check to see if the serpentine belt tool is available locally. EricTheCarGuy does mention it.
http://www.youtube.com/watch?v=Wg1AX77xEBQ
Old 01-11-2011, 11:32 PM
lesterl's Avatar
Harbour Freight sells 'em also http://www.harborfreight.com/serpent...kit-66344.html $17
Old 01-21-2011, 02:32 PM
merc81 merc81 is offline
Originally Posted by lesterl View Post
Sorry to jump in here late, but don't buy that belt wrench above! I have one and its too long to fit down in this van and pull the adjuster back with. You will end up just using your 3/8 drive anyway (which is too short for comfort). Maybe if you cut that long handle in half it might fit. . .
I bought a cheapo 3/8 drive from sears that was just the right length to give enough leverage but still fit in the space available in there. Since it was a cheapo, I positioned the drive just right and then hit the ratchet with a punch to lock it in place permanently. Its a belt tensioner tool now
Old 01-24-2011, 11:46 PM
lesterl's Avatar
NICE, thanks for the info man......... :-) BTW my brothers 94 Caviler Wagon is a SOB to change the belt on (couldnt fit a ratchet into it, so I just wheeled up on the belt by hand and pulled it off the alternator, back on the same way......)
serpentine belt help...please suzuki19 Cavalier Problem Diagnosis 2 07-10-2011 07:15 PM
replacing a serpentine belt schri00 Diamante 2 07-12-2010 09:00 PM
1999 pontiac sunfire serpentine belt repalcement glc4122 Cavalier Problem Diagnosis 2 10-05-2009 12:18 PM
How to Tighten Tensioner on Serpentine Belt - 05 G6 donnap1957 G6 0 02-26-2009 10:01 PM
replacing serpentine belt m22mike Park Avenue 1 08-09-2003 10:20 PM
