Old 01-09-2011, 02:45 PM
ipjkcu ipjkcu is offline
need advice tranny
ok iam new hear been reading post but now i need to ask some questions.
first off bought 95 metro 3 cyc. 5 sd. bad tranny. the clutch is shot spins when put in 4th w e-brake on the tranny will not shift in to 3rd or 5th gear. seller also gave me a different tranny says 2nd is shot and also a rebuild kit ( bearings,seals,secniorz) same as the one in the photo from dr bills tranny rebuild. what are my options for the tranny not going in to gear and what the easys way i should go. rebuild it my self, find used in wreking yard. or find out how much shop will charge to rebuild.
i ve never rebuild a tranny but ive done just a bout everthing eles to a car u can think of from rebuild motors to brakes and bodywork. mainly want to no what the problem is with it not going in to gear. i no i will have to split case to find out for sure and iam going to start withh the one that not in car. that supposedly 2nd dont work.
tips hints and advice are greatly appricated
thank you paul
western washingtion
Old 01-09-2011, 03:12 PM
Scrapper Scrapper is offline
AF Premium User
Re: need advice tranny
those cars when they came out they was suppose to be throw away cars. i went to hunter before they came out i was told this also they told us the drums and rotors would be throw also. a buddy of mine bought 1 and the tranny went out rite away i should tell you he bought it used with 30.000 mls on it when he bought it.
Old 01-10-2011, 03:41 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
I think you'll find this forum full of people who have driven Metros over 150 K miles with very little trouble. This completely wrong opinion is not going to fly here. Why don't you "go to hunter" whatever the hell that means, and learn some English.
To ipjkcu: It's out of the ordinary for anything to go wrong inside the gearbox except for worn 2nd gear synchronizers, and that's something you can live with. I would check your mounts and shift linkage before tearing anything apart. For the transmission to not go into gear, it must get full throw from the shifter, loose or sticky shift linkage bushings could compromise that.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 01-10-2011, 04:10 PM
mike68 mike68 is offline
I have rebuilt 2 of these transmissions. Its not too bad of a job, most i've seen have worn 2nd gear syncros. They don't require that much in the way of special tools. You need a press and a bearing seperator and some hand tools and thats it, but if you don't have a press you could get a machine shop to press the bearings on and off.
I also agree with woodie83 check the simple stuff first.
Old 01-11-2011, 09:28 PM
well like i said i have one tranny thats not in and i have a rebuild kit mite as well tear it apart have shop press bearing and sencrozos and put that one in since i have to replace clutch
Fender Bender - Need Advice on Repairs Panken202 Grand Cherokee | Grand Cherokee SRT8 3 10-24-2010 09:50 PM
Non performance tranny swap, need advice. racingnut10 Let's get Technical! 4 10-25-2004 07:02 PM
Non-performance tranny swap, need advice. racingnut10 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 10-20-2004 06:16 PM
My car tranny broke, need advice. 90Stangjc Mustang Talk 5 12-03-2003 07:20 PM
Need Advice About Engine/Tranny Swap issue Ebranste '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 03-20-2003 05:25 PM
