My car tranny broke, need advice.
Aiight, my auto tranny went out after like 1 month of driving the car. So now sense the trany's wrecked i'm going over to a T-5. I know some of the stuff i need for the change but if anyone knows some more stuff i would appreciate it.
What i know i need-Flywheel. Clutch pressure plate and throw-out bearing. Pilot bearing. Clutch cable. And the clutch pedal assembly w/ a shifter and knob. But i'm pretty sure there's something missing and i cant put my finger on it. I wanna know i got everything so i dont have to stop in the middle of the process. Also will my driveshaft fit with that tranny? Any help appreciated. BTW- How much tougher is a "World Class" T-5 than a regular T-5? |
Re: My car tranny broke, need advice.
This site has a lot of info on the T-5.
http://www.moderndriveline.com/Techn...ssion_spec.htm http://www.moderndriveline.com/Techn...automatics.htm Hope it helps! |
Re: Re: My car tranny broke, need advice.
Bell housing.
How much hp do you have. A stock T5 should be ok for a 5.0 with moderate mods. Also your auto drive shaft should be just fine even though it's weighted compared to a manuals d/s. Although I would suggest an alum one though.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
World class T-5s have a different gear ratio, and are rated somewhere around 325 pounds of torque. If you plan on driving hard, ever upgrading the heads, or running slicks/sticky street tires (or all of the above, which is usually the case), use at least a Tremec 3550. T-5's of any kind are not known for reliability under hard use, so why drop a grand into a timebomb?
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons..... http://www.cardomain.com/id/mccobra94 1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster. Freedom Isn't Free. |
Tremec TKO, the only choice. If you are going to do it, do it right the first time.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
Thanks for everything yall. I'm guessing my car has about 227 horsepower (Flywheel)...lol. Bumped timing, K&N, Flowmaster 2-chamber, off-road h-pipe, and that's all. Thanks for the advice on the Tremec's, but with an $6.50 an hour job (i'm 16), i dont think i'll have the grand for the heads, or $400 for the slicks, or however much it costs for the tremec's. Now for driving hard....only when i race, i usually baby it otherwise. Anyway's, thanks for the advice.
BTW- Have any of you ever installed a T-56? I REALLY like six-speeds and i figure if their as good as the Tremec's then i could drop one of those in their after i rip out the T-5. But ONLY if their as good or better than the Tremec's. |
