Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-08-2011, 11:00 AM
andybs andybs is offline
1999 Camry Starting problem
Hi,
I have a 99 camry, 4cyl, 165,000 miles. While, starting some mornings or been idle for few hours, car will start and die, unless I step on gas pedal for few minutes and hold, then runs fine.
Any suggestions, please.
Old 01-08-2011, 11:10 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: 1999 Camry Starting problem
I would clean out the throttle body, paying particular attention to spraying the cleaner liberally in to the square or diamond shaped hole in the base of the throttle body. That hole leads to the idle air control valve, where your problem may exist. They get gummed up over the years and can cause problems like you describe. Spray the cleaner down that hole first and let it soak while you go on to clean the rest of the throttle body.
Mike
Old 01-08-2011, 11:43 AM
Thanks Mike, I will let you know, how it goes.
Old 01-26-2011, 01:19 PM
rubs rubs is offline
I am having the same issues, Have you tried the fix?
Old 01-30-2011, 11:14 AM
Yes, it worked out, thanks to Mike for perfect solution.
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
1999 camry overheating problem mikie61 Camry/Camry Hybrid/Vista 0 07-05-2006 07:50 PM
98 camry starting problem sometimes Camry/Camry Hybrid/Vista 4 05-11-2004 07:12 PM
94 Camry Starting Problems Bantis Camry/Camry Hybrid/Vista 2 12-14-2003 09:16 AM
1990 camry starting problems bnguyen Camry/Camry Hybrid/Vista 1 11-26-2003 12:38 AM
