Old 01-08-2011, 03:42 AM
doctorhrdware doctorhrdware is offline
Replacing control arm
97 GP SE, has around 165,919. I will be replacing the control arms, will it be better to wait to get the to get the wheel alignment done after I change the control arms. Does it matter if I have the alignment done before I change the control arms, and get a new set of tires.
Old 01-08-2011, 09:31 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Replacing control arm
yeah, hold off before you get an alignment. Change your control arms first, unless you want to pay for two alignments. After I changed my control arms, my alignment was so far off that my steering wheel wouldn't return to center on its own after making a turn.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-08-2011, 01:16 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Tim is right, if you make an alignment before you replace them you'll need another one right after the replacement. Besides that the first alignment might not be accurate since you have a problem with the arms.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 01-08-2011, 06:05 PM
Thanks, Tim and Oscar, for your response to my question. That is what I thought, but I wanted to make sure that my assumption was correct. That will be a summer project, for my son and I. The cheapest price that I have found has been at Rockauto. The doorman's were like $65 dollar each. So I guess I will be ordering the control arms from Rockauto, unless someone can point me to another place on the web that is cheaper.
Old 01-20-2011, 02:57 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Is quality really a concern here at all? I mean they're just metal arms and rubber bushings, right? I'm thinking about going the same route as you doctor.
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 01-20-2011, 06:56 PM
olopezm's Avatar
I'm not sure about metal but bushings can get worn/rotted faster when the rubber is crappy. I might be wrong on this, but I've had problems before with cheap bushings on my lincoln.
There is one guy who says: "The quality will be remembered when the price is forgotten" of course that doesn't means you have to buy the most expensive they have, but you can do some research on the net.
Best regards,
Oscar.
Old 01-28-2011, 11:28 AM
00GTP4ME's Avatar
Have you ordered yours yet, doctor? I think I'm going to order mine today.
Let me ask you guys your honest opinions. You get get Dormans for $65. $20 and you can get Moogs. $20 more again, and you can get Raybestos. Do you really think the extra $20 in each case is worth what you are getting in return?
Old 02-02-2011, 02:33 PM
00GTP4ME's Avatar
Well I decided to go with the Moogs. They have greasable ball joints, which is cool!
Old 02-10-2011, 06:29 AM
Sorry I have been laid up with a really bad sinus infection, so have not been really paying attention to the replies. I also believe that the doorman's have the lower ball joint grease fitting on them also. I will be ordering the control arms from rockauto.
Old 03-03-2011, 11:18 AM
00GTP4ME's Avatar
How in the world do you get these stinking sway bar links off?? You know that plastic center piece that goes between the sway bar and the control arm? Is that thing threaded to the bolt somehow? I have no clue how to get that off aside from just sawing everything apart. Tips? haha
Old 03-03-2011, 11:27 AM
tblake's Avatar
In God We Trust
Saw it apart. It just slides over the link, but the center gets rusty and makes it impossible to get apart. I just cut mine and replaced them.
Old 03-03-2011, 12:21 PM
00GTP4ME's Avatar
Gosh dang that was frustrating. I partly expected everything to just crumble off, but when it looked in decent shape I thought it would be fairly easy. That stupid plastic sleeve drew a lot of cussing out of me. haha. But okay, if that's my only choice, I can just saw it off - I ordered some Moog links with the new arms so not a big deal I guess.
Old 03-03-2011, 01:22 PM
tblake's Avatar
In God We Trust
Yeah, that or grab a big sliding pliars or vice graps and clamp on the center plastic piece to break it. Do what you gotta do.
Old 03-03-2011, 02:08 PM
00GTP4ME's Avatar
K. I'll probably let my 4" grinder with a cutting blade take care of it then. Piece of crap.
Old 03-11-2011, 11:14 AM
00GTP4ME's Avatar
Anyone have torque specs for those control arm bolts and the ball joint/TRE castle nuts?
Replace control arm bushing? autoa PT Cruiser | PT Cruiser Convertible 9 01-17-2011 10:33 PM
replace control arm or just ball joint? raayven420 Wheels/Tires/Suspension 3 09-17-2007 01:22 PM
replacing control arm bushings fasthatchb18c1 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 04-17-2007 08:54 PM
replacing control arm? Is it difficult? dmorlow Aurora 12 11-22-2004 05:21 AM
