Replace control arm bushing?
I finally found my clunk on the 05 convertible. It is the passenger side control arm bushing (rear). Is it difficult to replace? Are there any tricks or special tools needed?
Thanks in advance, Don |
Re: Replace control arm bushing?
We are buying a 2001 PT that also has a clunk at the passenger front end. I'm assumming that it is a control arm bushing as well. Has anyone done this repair? I have done it on other vehicles and it was real asy.
I havent seen any control arm bushing failures but I have seen the bell crank on the rear suspension fail and many upper strut bushings and bearings fail. The repalce ment of the control arm bushings will require a press.
BR549 |
Have To Replace Control Arm Assy.1-2hrs Repair
for front end clunks, check the sway bar mounts. i had a terrible clunk on my 03 and ordered all new bushings when i got it apart the only thing wrong was the sway bar mounts and you can get urethane ones for about 10.00
Yes, the contol arm bushings are a problem. Also the sway bar bushings. If you don,t have power tools, let the dealer do it. I just sold mine after five years and replaced the contol arm bushings 3 times. Also a horrible clunck can come from the sway bar bushings but cheaper to replace. It will happen again.Good luck.
I have notced over the years that when you jack up your front tire as a example, there is stress on those bushings. Wish I could tell you why. Last edited by yale329; 06-12-2010 at 01:43 PM. Reason: I thought |
Did the sound come and go or happen all the time. I have a grinding sound that comes and goes but when it happens it is from a stopped position. The sound is for a second but noticable.
We have that clunking sound also on our 2001 pt and it always dose it when on highway goin speeds 60 and up we really hear it when we switch lanes while goin 60 and above sounds like its on passanger side front where should i look 1st ? thanks for taking the time to view this post.
My clunking sound was the motor mount. Easy to repair.
