Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 01-06-2011, 04:07 PM
NAVY_MA1027 NAVY_MA1027 is offline
1990 4runner 4wd problems
Hi guys,
i have a 1990 4runner that had the ADD 4wd system in it. I read and read about it so i changed the ADD to warn Manual hubs(pretty easy swap). Went to the desert and mud to test it and again, no indicator light or front wheels moving. I got stuck):. also when i go into 4low i can feel the gearing turn like it wants to be in 4low but the front tires still dont move.....HELP ME!!!! and yes i did make sure the manual hubs were locked into place....
Old 01-08-2011, 06:28 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1990 4runner 4wd problems
Did you leave the ADD actuator mechanism in place in the differential housing? Vacuum lines and switches?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 01-10-2011, 08:04 AM
chopperjerin chopperjerin is offline
I have the same problem with my 4x4 and everything I've read points to the vacuum lines on the ADD system. Some have suggested pulling the actuator and locking the fork in place to get rid of the electrical and vacuum system completely without replacing the tube... I want to know if there's a good way to swap some vacuum lines and permanently leave the 4wd engaged when the motor is running. With manual hubs I don't see the problem. Any thoughts?
Here's a link to the referred page: http://www.yotatech.com/f129/add-man...er-mod-200971/
2001 Rodeo 4wd problems Derman Rodeo | Passport | MU 2 01-20-2010 08:49 PM
90 4runner rubbing noise? sickboy13 4Runner/GX470 1 01-02-2010 12:30 AM
1990 Toyota 4runner 4wd system jetwhine 4Runner/GX470 4 03-16-2009 07:52 PM
4WD problem on 96 4runner Lillee 4Runner/GX470 2 02-13-2007 12:18 PM
1990 4Runner 4WD Problem Vegas Z71 4Runner/GX470 2 12-30-2004 10:56 PM
