Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-04-2011, 07:39 PM
Z71 Thumper Z71 Thumper is offline
Z71 tahoe 2000
My tahoe started today really rough every time I accelerate a forceful sound where you hear some aluminum or metal bouncing on the bottom of the car as well when I let go of the accelerator the truck comes to a complete stop. When I try turning right I need to force the gas or it would not accelerate. Would this be a suspension problem?
Old 01-05-2011, 08:27 AM
j cAT j cAT is offline
Re: Z71 tahoe 2000
how do you go from rough start to steering, to throttle issues..
post back with a better detailed discription of what is going on.
Old 01-06-2011, 07:22 AM
4x4junkie 4x4junkie is offline
Re: Z71 tahoe 2000
Did you drive over something or back over something that may have smashed the lower access plate between the transmission and engine that allows access to the flywheel and torque converter causing a binding issue between engine and the transmission? It might explain starting roughly by preventing the motor from turning freely while starting, a rubbing noise while running you would hear at idle or higher rpms, sluggish acceleration, and rapid deceleration.
2000 z71 tahoe top dash and air bag remove and replace Z71 Thumper Tahoe 4 01-05-2011 05:46 AM
Problem with 4WD. 2000 sierra k1500 Z71 truckguy92 Sierra 0 09-26-2010 12:56 AM
2000 z71, 5.3 budget rebuild, any tips nthnkng33 General Discussion 2 07-20-2010 09:06 PM
2000 Z71 Tahoe transfer case trouble Dareman463 Tahoe 4 03-08-2010 06:17 PM
2000 Z71 Tahoe heated seats went out? Tmann22 Tahoe 0 01-21-2008 10:29 AM
