Old 01-02-2011, 11:57 PM
FORDGUY09's Avatar
FORDGUY09 FORDGUY09 is offline
Send a message via AIM to FORDGUY09 Send a message via MSN to FORDGUY09 Send a message via Yahoo to FORDGUY09
Exclamation 88 F250 problems
got a 88 F250 with 5.0 302 just warrantied out the plug wires changed the plugs and plug wires are starting to ark off of the engine block again what could be wrong?
any help would be great and thank you for any help in advance
1997 Honda Accord
2003 F250 6.0 ps cclb
2016 jeep patriot
Old 01-03-2011, 08:05 AM
snshddog snshddog is offline
Re: 88 F250 problems
Is it a particular wire that is arcing or all of them. Is it a regular 302 or is it an HO motor? On the HO i know if you run wires for 7 and 8 next to each other they will arc through 7, 8 and for some reason 4. So if it is the HO then with new wires keep 7 and 8 as far apart as you can. Other than that check the routing for all wires. It makes a difference where they go.
Old 01-03-2011, 11:26 AM
mechhound mechhound is offline
You may have to get a different brand of spark plug wires.
Old 01-06-2011, 11:02 AM
FORDGUY09's Avatar
O do i wish i was running the HO lol naw i got the standard 302 with 207,xxx miles on it. In the last 6 months have replace timing chain, cover, cap, rotor, plugs, wires, just stumped on it
1997 Honda Accord
2016 jeep patriot
Old 01-06-2011, 11:50 AM
Scrapper Scrapper is offline
AF Premium User
you cant take and put spark plug wire clips on to keep them away from exaust manifold there plastick? if not like he said may have to diffirent wires on or just go get oe's to put on it? you don't have to go to dealer any parts store will have the oe's.
Old 01-08-2011, 01:21 PM
FORDGUY09's Avatar
its hard to explain where its sparking from but here it goes..... where the plug screws into the heads and the plug wire boot goes over the plug is where it is sparking at
1997 Honda Accord
2016 jeep patriot
Old 01-08-2011, 02:51 PM
Do you by chance have a bunch of dried grease or fresh oil by the spark plugs? Other than that I would say defective NEW spark plugs or spark plug wires. I don't know what else it could be. I prefer Autolite or Motorcraft spark plugs and Motorcraft or Belden spark plug wires.
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
93 f250 problem civic93gsr F Series 3 07-24-2007 04:32 PM
85 6.9l F250 Problem! HondaProblemBoy F Series 0 05-21-2007 07:38 PM
86 f250 problems andimal F Series 1 10-13-2005 03:38 PM
