Old 12-31-2010, 02:23 PM
jamesmetairie jamesmetairie is offline
don,t replace multifunction lever=-
let,s say your multifunction ain,t functioning right. rear barke lites ain,t illuminating. center high is. don,t want to tackle removing steering wheel. no problem=- just run a wire from the center high to each rear brake lite.
will it work is the question.
Old 01-02-2011, 07:48 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: don,t replace multifunction lever=-
Just do it right and be done, you are destined to fail if you attempt a cobble job in this case.
It won't work anyways. You'd need to run a wire to both sides since each side has it's own circuit and even then your turn signals still won't work while your foot is on the brake pedal so that would really defeat the purpose. How many times do your use your turn signal without hitting your brakes? Perhaps during lane changes, but that's about it.
I don't see what the big deal is. It took me about an hour to install the turn signal switch in my 1995 Buick Regal a few years ago. I had minimal automotive experience at that time too. It's not that hard. I'd say the hardest part is getting the C-clip off that holds the lock plate on.
I'd probably rank it about a 3/10 in terms of overall difficulty if you have the right tools. You can rent a steering wheel puller and a lock plate hold-down tool from a local auto parts store for a net cost of free (requires deposit).
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 01-02-2011, 08:48 PM
i was just joking around. actually when i work on a car i fix one thing and break two or three. my shadytree mechanic has been busy and ain,t got to my car yet .
anyway thanks for the advice.
jamesmetairie
83 Multifunction Lever justdivin Eighty Eight 0 11-06-2005 04:08 PM
replaced multifunction switch now horn honks randomly carstupid Grand AM 1 04-30-2005 08:15 PM
MultiFunction Lever 85 RageCage Caprice 7 12-14-2004 05:10 PM
