Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-12-2004, 10:35 AM
RageCage RageCage is offline
MultiFunction Lever 85
Hi,
How much of a pain is it to replace a multifunction lever on an 85 Caprice ? I think the wiper controls may be worn out. Low, High, and intermittent don't work at all today. Yesterday they were working, but not properly.
I can't see any screws to remove to get the lever out, or to remove the steering column.
Thanks
Old 12-12-2004, 03:19 PM
CD Smalley CD Smalley is offline
Re: MultiFunction Lever 85
find the wiring harness connection under the dash and disconnect them. Then just pull on the lever. It will come out.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 12-12-2004, 03:48 PM
Thanks.
Old 12-12-2004, 04:36 PM
TommySS TommySS is offline
Are you sure it's the switch? How about checking the electronics under the hood on the wiper motor.
There's a circuit board that also causes problems.
Old 12-13-2004, 08:11 AM
Re: Re: MultiFunction Lever 85
Well, I replaced the circuit board / washer pump combo yesterday, and the wipers work again, but they stll are weird. They park after each sweep. Only intermittent works normally.
And if I use the high setting, the motor squeals and smoke comes out of the motor (or maybe the washerpump that is mounted to it) !!! I am serious. I'm afraid to use the high setting.
Maybe the motor is going bad. Squealing is just not right. Would a bad motor make the wipers park after each sweep? Maybe the bad motor is screwing up the circuit board? Jeez.
Old 12-13-2004, 06:32 PM
I ended up installing a new wiper motor too.
Old 12-14-2004, 02:40 PM
Ii just installed a rebuilt wiper motor which also had the washer pump / circuit board on it, and everything works right !
Old 12-14-2004, 05:10 PM
woo hoo!
