Old 12-29-2010, 07:12 PM
blendmik blendmik is offline
Send a message via Yahoo to blendmik
First Post photo question
Hey modelers, I tried posting a photo for my first post and I got a red X instead of the pic........how do you post images her?..., thanks!
Old 12-29-2010, 08:26 PM
Drift F.C's Avatar
Drift F.C Drift F.C is offline
Re: First Post photo question
If you right click on the image in question and click properties you will see the direct .jpg URL for the image. Copy this by highlighting and copying (CNTRL+C) then paste (CNTRL+V) into the insert image window of the post (click on the yellow icon of the mountain.)
Hope this helps, if not, just post back with a question
or
Old 12-29-2010, 08:56 PM
drunken monkey's Avatar
Razor Sharp Twit
first of all, you will need to host your images on an online.
popular choices are imageshack and photobucket.
once that is done, when you are viewing your hosted image in its album, there will be a set of posting codes.
in this case, they're in a box labelled "share this image"
(not my model or my photo - i pulled this screenshot to answer the same question another time)
this is the complete url+img tags of the image that you will want to insert into your posts.
what the "mountain" icon that was mentioned does is put the [img][/img]tags around a url.
as you can see, it is already done for you on the photo host.
AF's Guidelines
Read them.
Old 12-29-2010, 09:45 PM
I'll try that, thanks!
Old 12-29-2010, 09:48 PM
Hey Drunken, thanks. I already have them on my blog, Fotki and in my pc. I will try it again, but it says you can upload from your pc also?
Old 12-29-2010, 09:53 PM
Razor Sharp Twit
i wouldn't recommend using the upload option.
it makes them appear as a pop up here and when there's a lot of photos, it's easier to "read" the page if they're inserted into the post.
if I recall, there's a button on the fotki page that says "share file" that you click.
the url should be posted there.
you can simply copy this into the post and put the [img][/img] tags in yourself or use the "mountain" button and copy url into the dialogue box.
AF's Guidelines
Read them.
Old 12-29-2010, 10:08 PM
Yes, well I got a couple posted ok, but I could'nt post more then one and the second post I got the same pic twice in diff. sizes, so I am still doing something wrong I guess, thanks tho.
I got a couple up, not correct yet, but at least they are on the post.......grrrrrr..thanks tho!
I tried that and as you can see got on or two up somewhat okay, but the Ford I posted came out tiny when you click on the link to Fotki. I'd like to show them like the ICE Truck.........grrrrrrrrrr.
I guess I did something wrong again because the Ford pics with a link all came out tiny with little squares around it.........one of these days I guess.....grrrrrrrrr...
TEST:
grrrrrrrrrrrrrrrrrrrrr!!!!
TEST 2 :
Last edited by drunken monkey; 01-02-2011 at 02:29 PM. Reason: back to back posting consolidation
Old 01-02-2011, 02:28 PM
Razor Sharp Twit
once again, because you are clearly not doing what I said.
in photobucket, when you are viewing an image, on the right hand side is a little box that says share this photo.
in that box look for the one that says IMG code.
when you click it, it automatically copies it (it even says so when you click it)
use this in your posts to insert the image.
you do not need to do anything to this copied code except paste it into your post.
do not right click - properties as it doesn't always give you the correct url.
when you use the IMG code, do not use the insert image icon (the little mountain).
AF's Guidelines
Read them.
Old 01-02-2011, 08:29 PM
Sorry for inconveniencing you again and thanks for your re-up on the instructions.
Old 01-02-2011, 08:41 PM
Worked perfect this time...check it out. Thanks for your patience.
First post and questions about airbrushing Chieflongshin Car Modeling 4 09-17-2010 03:08 PM
First Post - Introduction/Question FellintoOblivion General Discussions 3 09-10-2005 06:45 PM
First post on new board and guages question Bleebdat '88 - '91 Civic | CRX | Wagon | Shuttlee 14 07-25-2005 09:01 PM
My first post, noob question SkunkMonkeY Integra 8 10-12-2003 01:53 PM
First post!! Important question about engine swap kane_abel '88 - '91 Civic | CRX | Wagon | Shuttlee 10 06-15-2002 11:50 PM
