Old 12-27-2010, 07:13 PM
g8t255 g8t255 is offline
98 blazer heating problem.
Hi. I have a 98 blazer with the computer controlled heater. My problem is this: The heater blows really hot air on max heat set to the defrost position. If you turn it to any other position, be it vent or floor, the fan slows right down but the heat stays hot. In addition, if you turn anywhere off of max heat, even a click or two the temp goes way cold. Any ideas? I am thinking it might be the module mounted to heater box under hood?
Old 12-28-2010, 07:10 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 98 blazer heating problem.
Auto matic heater controls?
Battery been changed or a dead batter witha a jump start?
Try the relearn procedure.
If that does not help you may need to get it on a HAVC body heater control capable scanner and see what is going on.
If any HAVC /heater control codes post back code no.
MT
Old 12-28-2010, 08:01 AM
Thanks for the reply. I did change the battery this past summer but no boosting. How do you do the re learn on this truck? I just learned how to do it on my Caravan but not sure how on the 98 blazer.
Thanks.
Old 12-28-2010, 08:03 AM
Sorry, Yes it does have auto heater controls. I will see if my local parts source has the havc code reader.
Thanks.
Old 12-28-2010, 09:28 AM
MT-2500's Avatar
AF - Advisor
It may not have the cry type relesarn.
But computer can be reset by pulling the fuse or disconnecting the neg battery a few minutes cable and phooking it back up.
But first check and clear codes and see what comes back also watch havec operation on scanner.
Most parts places do not have scanners capable of checking HAVC.
Good repair shop with a good trained tech/mechanic is best bet on that end.
MT
Old 12-28-2010, 04:06 PM
Thanks. I will give the negative cable a try and see what it does. I will check with my local GM dealer and see what they would charge me to scan it.
1998 Blazer Heat Problem again melam Blazer 5 12-29-2010 09:10 AM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
96 blazer heating problems redstarr681 Blazer 2 10-08-2005 09:04 AM
2000 Blazer Heating Problem ripcordres Blazer 15 01-23-2005 07:26 PM
1998 Blazer Heating problem jdizil45 Blazer 5 01-10-2005 10:59 AM
