96 blazer heating problems
im in need of help! My heat doesnt work and its 34 degrees here in nebraska! Last winter and summer i didnt have heat or ac but this summer i had ac. What can i do about the heat? ive done a radiator flush and replaced the thermostat. When i put on the heat all that blows out is ice cold air what am i to do?
Re: 96 blazer heating problems
After the engine has warmed up, touch the two heater core hoses going into the firewall. If one is hotter than the other, then the heater core is clogged and needs to be flushed.
Check/feel the heater hoses at the heater core.
If both are cold remove them from heater core and hook a water hose or low pressure air hos to the heater core and see if it is stopped up. I have had the clog up but if you can back flush them or get any water going threw it switch the heater hoses for a few days and see if that helps clean it out. If not you will need a heater core. MT-2500 |
