Old 01-07-2005, 07:34 AM
jdizil45 jdizil45 is offline
1998 Blazer Heating problem
My heater used to work just fine and then all of a sudden, it takes a real long time to heat up. Like it only heats up while I'm on the freeway. Any ideas???????????????????????????????
Old 01-07-2005, 08:50 AM
swalt's Avatar
swalt swalt is offline
If you are not overheating, then your heater core is blocked. Get the system flushed and refilled and specifically tell them to check the heater core for flow. If you have Dexcool, you are either getting air in the system (from a bad rad cap) or the Dexcool has outlived its life and is getting gummy. If the truck is running cold as inidicated by the temp guage, your thermostat is likely stuck open.
Old 01-07-2005, 09:48 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1998 Blazer Heating problem
What does the temperature read on the temp gauge?
1/4 1/2?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-10-2005, 07:51 AM
Thanks for replying fellas. The temp sits at a lil below half.
Old 01-10-2005, 10:13 AM
Fractured1 Fractured1 is offline
sounds like the temp is within range, is your radiator topped off with coolant...also I would look towards possible air in your system, mainly in your hearter core itself...if you are getting heat at highway speeds I wouldn't think it would be a blocked core...also check the radiator cap...
Old 01-10-2005, 10:59 AM
BlazerLT's Avatar
AF -Advisor
Sounds like it is time for a cooling system and heater core reverse flush and fill.
