Go Back   Automotive Forums Car Chat > Chrysler > PT Cruiser | PT Cruiser Convertible
Old 12-15-2010, 07:43 PM
fine69lc fine69lc is offline
Bad 01 cruiser engine. Will 98 stratus 2.4 fit?
I have an 01 pt cruiser with a bad 2.4 dohc head and block. Can I swap it with a 98 stratus 2.4 dohc engine by using all of the parts off of the pt cruiser engine? I know i will have to use the oil pan, mounts, manifolds, and such from the pt(if they will bolt up). Does anyone know if this will work before I buy the stratus engine? Is it the same block and head for the most part?
Old 12-15-2010, 07:50 PM
urclueless urclueless is offline
Banned
Re: Bad 01 cruiser engine. Will 98 stratus 2.4 fit?
www.car-part.com this is a method I use to check interchangeability. I know they won't list the entire engine as compatable. Hollander exchange manuals are specific as an EXACT fit. one sensor that doesn't fit will void their interchangeablilty. However I break down the parts to check for fit. so do a search for a head if they come back the same then you'll know the manifolds will fit. search the block, if it comes back as a valid interchange, you'll know this will work.
Last edited by OnThePike; 12-17-2010 at 09:06 AM. Reason: See User Details & AE Trip Log
Old 12-16-2010, 10:19 AM
Thanks for the reply. Great Link! I could not determine from it if the engine or head would work. I know the casting numbers are the same on the heads, I read on another web site that the oil passages inside the engine are a bit differant, but if I used the entire engine it wouldnt really matter. the block looks very similar as well, but its one of those deals where I look at mine, and drive to the salvage yard 70 miles away and try to remember if they are the same. I was hopeing someone had done the swap, or knows 2.4s well enough to know if it would work, or if they are totally differant engines. I also have a low low milage 2.0 from a 2001 neon available. Would that work without changing any internal engine parts(cams, ect..)? Id like to use the harness from the cruiser with as many parts from the cruiser as I can.
Stratus misses on 1 & 4 titanthree Stratus 3 07-16-2010 02:31 AM
2000 dodeg stratus, 2.4. lost the timing marks fishpaste Stratus 1 07-30-2009 11:18 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 08:59 AM
Will a 2.4 liter RT4 engine from a neon fit into the 99 sunfire gt? Madrox_xordaM General Discussions 2 10-24-2007 11:49 PM
1996 Dodge stratus 2.4 Engine Specs??? mikeypooh1 Stratus 5 02-28-2005 12:45 PM
