Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 02-19-2005, 11:52 PM
mikeypooh1 mikeypooh1 is offline
1996 Dodge stratus 2.4 Engine Specs???
Does anyone know what the engine specsare for a 1996 Dodge stratus 2.4 ?
Old 02-23-2005, 05:14 PM
lvd2340 lvd2340 is offline
2.4L ENGINE SPECIFICATIONS
2.4L ENGINE -
Type In-Line OHV, DOHC
Number of Cylinders 4
Bore 87.5 mm (3.445 in.)
Stroke 101 mm (3.976 in.)
Compression Ratio 9.4:1
Displacement 2.4 Liters (148 Cubic Inches)
Firing Order 1, 3, 4, 2
Compression Order 1172-1551 kPa(170-225 psi)
Maximum Variation Between Cylinder 25%
Lubrication Pressure Feed-Full Flow Filtration(Direct Crankshaft Driven Pump)
Engine Oil Capacity With Oil Filter 4.7 Liters(5.0 Qts.)
Engine Oil Capacity Without Oil Filter 4.3 Liters(4.5 Qts.)
Old 02-23-2005, 11:05 PM
thanks. Do you know the horsepower and torque?
Old 02-25-2005, 02:11 AM
speeder94 speeder94 is offline
Re: 1996 Dodge stratus 2.4 Engine Specs???
horsepower?
Old 02-25-2005, 10:25 AM
Yes horsepower and torque
Old 02-28-2005, 01:45 PM
Type and Displacement 2.4-Liter, DOHC, 16-Valve, SMPI I-4
Construction Cast iron block and bedplate, aluminum head and balance shafts
Power (SAE net) 150 bhp (112 kW) @ 5200 rpm (62.5 bhp/liter)
Torque (SAE net) 167 lb.-ft. (226 N-m) @ 4000 rpm
Max Engine Speed 6240 rpm
Fuel Requirement Unleaded regular, 87 octane(R+M)/2
