Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-13-2010, 10:21 AM   #1
1BIG77CRAWDADDY
96 OLDS Cutlass Supreme wipers no work...
Windsheild wipers stopped working. Tested moter and works fine. But they only work when you ground the motor. Any suggestions?
1BIG77CRAWDADDY is offline   Reply With Quote
Old 12-13-2010, 11:00 AM   #2
D Ryan
Re: 96 OLDS Cutlass Supreme wipers no work...
I would suspect a broken solder joint in the pluse board thats inside your wiper case.
A quick test for this is to turn wiper to on position then lightly beat on the wiper case see if it tryes to start moving, if it does you can remove the pluse board and with a magnifing glass look for a 360 degree crack around the solder joints, you can remelt the solder and be in bussiness again. This worked for me 3 years ago and its still going.
could also be a broken ground wire to the wiper!
My 2 cents
Denny
D Ryan is offline   Reply With Quote
1991 OLDS Cutlass Supreme SL 2-door keyless entry module PAPAJACK Cutlass Series 0 07-31-2010 10:56 PM
How to change wiper blade? serge_saati Cutlass Series 3 01-03-2010 01:08 PM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 08:15 AM
94 Cutlass Supreme Wiper Problem tedmel Cutlass Series 3 10-08-2007 02:32 PM
93 Olds Cutlass Supreme trans trouble dunlapr Cutlass Series 7 02-24-2005 02:20 AM
