Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-05-2007, 07:47 PM
tedmel tedmel is offline
Angry 94 Cutlass Supreme Wiper Problem
I have a 94 Cutlass Supreme 3.1 V6. I had the problem with the turn signal switch where the right brake light wouldn't work when the left signal was on. Another odd thing was the wipers and washers would only work with the left signal on. Well I replace the turn signal switch and now brake lights and turn signals work fine but my wipers and washers now do not work at all. I checked fuse and it was fine. Any ideas? Is there a relay or anything else?
By the way it has intermittent wipers if that makes any difference.
Old 10-05-2007, 09:57 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 94 Cutlass Supreme Wiper Problem
Welcome to AF.
Did you replace the multi function switch(MFS) with a new one ??
If so then you might have a connector loose or damaged when the MFS was installed.
Thier is a relay but I'm not certain where its located, could be the culprit though.
1999 Grand Am SS 3.4 OHV
Old 10-06-2007, 02:19 PM
MFS? Would that be the actual lever with the cruise and wiper controlls? If so no I did not change that. I did change the turn signal switch inside the column though. Is there a way to test it? I know there are 4 wires specifically for the wipers. I believe pink, purple, gray, and dark green. Should there be any resistance through any of those or power running to them? I checked them for power but didn't get any. I tried to trace the wire from the fuse block but the cluster got to be to massive.
Old 10-08-2007, 01:32 PM
xeroinfinity
Thanks for the help. It was the MFS. One of the wires broke off the connection. A little solder and it was all fixed. Thanks again.
