Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-11-2010, 12:45 PM
68ragtop 68ragtop is offline
98 3.4 ignition issue
Hi Guys, Trouble shooting my wifes 4runner. Has a severe miss that comes on as soon as it warms up. Only code it is setting is a misfire on #2 & #5
In troubleshooting it, I found the coil for #2 was firing the spark 2X times what it should be at. (compared to the other two coils) I swapped the coil with one that is worlking correctly & the problem stayed in the same bank. So, what I learned is that the ECU is probably telling the coil to fire at an accelerated rate, & at the wrong time.
Any guesses? Cam position sensor? Crank position sensor?
Its not setting a code for anything but the misfire..
I am not too familiar with toyota, & don't want to start throwing money into a sensor it might not need.
Thanks, 68RT
3.4 From 2003 Monte Carlo into 94 Firebird? iamdallas Engine and Transmission 0 03-21-2010 08:39 PM
2000 2.4 Stalling Issues SteveFord26 Cavalier Problem Diagnosis 7 09-11-2009 08:56 AM
99 alero 3.4 cruise issue lucky99alero Alero 5 03-16-2009 07:56 PM
96 Monte 3.4 overheating issue nickdrivesa96monte Monte Carlo 3 03-29-2007 10:29 PM
92 3.4 ignition problems please help gdk001 Lumina 4 12-23-2003 03:43 PM
