Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-10-2010, 09:47 AM
Korni Kovac Korni Kovac is offline
Malibu wont start when cold
Chevrolet Malibu 2003 95000Km, V6.
Wont start when -5 or colder for the first start in the morning. With block heater for one hour, car start (not easily of coarse but start).
Changed battery 2 years ago, checked it and it is OK
Changed fuel pump and filter (AC Delco) a year ago. It should be ok.
Changed sparks, cables, and air filter a week ago.
Problem is still there.
Any idea, please.
Thank you
Old 01-04-2011, 11:22 AM
Re: Malibu wont start when cold
I've changed coolant temperature sensor, it is little better, but the problem is not solved. It is still difficult to start if the temperature is -10C or lower.
Old 01-17-2011, 07:24 PM
Tripledash8 Tripledash8 is offline
Hi there, did you hear if the fuel pump turn on when you turned the key in the "on" position? If not it could be that malfunctioning. Another thing could be your timing belt. If it is not aligned, it could affect the way your engine starts.
Old 01-19-2011, 06:09 AM
ac700wildcat ac700wildcat is offline
You might want to try a bottle of heet in your gas. A car that I have would have a ton of troubles starting in the cold weather even tho last year it would start even when it was -30F. I put in a bottle of heet and topped off the gas and the problem went away. Might not fix your problem, but its only a few bucks to try it.
Old 01-26-2011, 12:45 PM
When I turn the key in the "on" position I hear the fuel pump, so I think the problem is not there.
For timing belt I cannot confirm. In that case would the problem be there only in cold weather ?
I'm already using "heet" during winter.
Thank you
98 Malibu hard start when cold Newbu Malibu 8 05-18-2009 04:34 PM
2000 F-250 Wont Start When cold romapint F Series 9 02-28-2005 08:36 AM
98 blazer wont start when cold jimmybob S-10 0 12-31-2004 01:52 AM
S 10 Blazer wont start when cold. lanestewartsr Blazer 0 04-22-2004 08:40 PM
88 s10 wont start when cold knuclemul S-10 4 03-15-2004 07:40 AM
