Old 02-23-2004, 11:28 AM
knuclemul knuclemul is offline
88 s10 wont start when cold
Having trouble starting my 88 s10 4 cyl. Starts and runs fine after it warms up. Have replace tbi, intake manifold sensor, new coil, new dist cap, wire, plugs, rotor button. will start with starter fluid when cold but runs rough until warm. I found one similar question submited dec 2002 but no answers. Thanks for any help
Old 02-23-2004, 12:14 PM
85S10358 85S10358 is offline
Send a message via AIM to 85S10358
try a thinner oil ... When its cold and u go to start it.. It takes a while for the Oil to warm up which would prlly explain the running rough thing until it warms up... Try somethin a little bit thinner for oil
Old 02-23-2004, 11:32 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 88 s10 wont start when cold
check your fuel pump relay. do you hear the pump power up when key is turned to run? should buzz for a couple of seconds. it sounds like the fuel pressure is bleeding off. if you put a gage on it you'll know for sure. pressure will bleed if you have a bad regulator, bad pump check valves. i don't think oil is your problem
Old 02-27-2004, 01:59 AM
DSSDOG's Avatar
DSSDOG DSSDOG is offline
Send a message via Yahoo to DSSDOG
Some 1987-88 S/T pickups may experience a condition where the fuel in the fuel lines drains back into the fuel tank after the vehicle is turned off and not restarted for a period of time, usually overnight or longer. This condition may be caused by a leaking check valve in the in-tank fuel pump. Effective Julian date 1218 (May 1, 1988) a change was made to correct this condition.
When replacement of the fuel pump is necessary, the manufacturing date of the new fuel pump should be checked before installation. The Julian date of the new fuel pump can be found stamped on the side of the fuel pump housing. Only install fuel pumps with a Julian date of 1218 or greater.
Example 1218-1 = May 1 1988 on 1st shift.
I would also check the Coolant Temp Sensor to make sure it's functioning properly.
Welp Good Luck Adios..
w00F...
Old 03-15-2004, 07:40 AM
I replaced the coolant sensor, replaced the fuel pump, still have the same problem. I can see fuel being sprayed in the TBI when someone tries to start the truck but it will not start. As soon as I spray starter fluid in it the truck will start, run rough until warm then run great. I have checked the codes and it does not have any codes set. Had the ICM checked this weekend and it checks out good. truck has 160000 miles.
Still looking for a solution.
