Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 12-07-2010, 09:20 PM
venturenot venturenot is offline
Rotating Engine for service access
Ok, the instructions for rotating the Engine are listed below:
  1. Remove the throttle body air inlet duct.
  2. Set the park brake.
  3. Shift the transaxle into Neutral.
  4. Remove the engine mount strut bolts. Swing the engine mount struts aside.
My question is: It says swing engine mount struts aside. Does that mean that they rotate upward. In the image do I remove the bolt in the yellow circle then swing the horse shoe (blue) upward?
Also, is there anything else that I should remove other than the air duct, Are the throttle cables OK?
Old 12-07-2010, 10:22 PM
lesterl's Avatar
lesterl lesterl is offline
Re: Rotating Engine for service access
Pull the blue bolt, then off the bottom of the picture, pull the 4 bolts out and remove the whole assembly, do that for both sides. Use a ratchet strap from one of the loops on the front of the motor to the bottom on the cradle, use the ratchet to pull the motor forward.
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 12-07-2010, 10:38 PM
I still don't get what they mean by swing the engine mount struts aside. From what you are saying, you remove the bolted down section and nothing swings to the side.
How far does the engine rotate? Is it OK just to remove the air duct or should I remove something else.
Old 12-08-2010, 10:49 PM
lesterl's Avatar
Remove the duct, the engine should come forward a good few inches.
What are you servicing?
Old 12-08-2010, 10:56 PM
EGR valve. I thought that maybe rotating the engine would make it easier to get at the back bolt.
Old 12-09-2010, 10:35 PM
lesterl's Avatar
Its possible, good luck on the valve.....
3.4 engine rotation to gain better access Cressidaadr Venture 5 11-21-2008 03:44 PM
Rotating engine forward? mntmartinez Venture 2 03-29-2005 03:36 PM
Engine won't start for me, but starts for service techs ksesci C/K 5 07-12-2004 02:21 PM
Rotating Engine to change spark plugs ShuDawg Grand Prix 13 05-31-2004 10:33 PM
Multiple Causes for Service Engine Soon Light MikeatSD SC/SL/SW 0 04-17-2004 06:53 PM
