Old 05-13-2004, 12:43 AM
ShuDawg ShuDawg is offline
Question Rotating Engine to change spark plugs
Ok I'm not sure on how to do this. So you loosen the front two motor mounts then pry like hell with a metal bar to get it down. But if you loosen the mounts won't it roll all the way forward and hit something? And if it is hard to get it to rock forward won't it be hard to get it back up. Help would be greatly appreciated.
Old 05-13-2004, 04:26 AM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: Rotating Engine to change spark plugs
the bottom mounts and trans keep it from moving too far to hit anything
Undo top mounts then have someone push the car and when the motor is rocked as far forward as possible engage parking brake
Old 05-13-2004, 08:09 PM
GTPCatz GTPCatz is offline
Banned
Or if you look at the right Brace there is a hole a little further back then the hole that it is currently sitting in.
Rock the engine forward and slide the screw into that hole holding the rest f the dogbone.
Old 05-14-2004, 04:54 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Just take the bones out, push the car until the engine rocks all the way to the front. Apply parking brake and proceed to do what ever you need to
Old 05-15-2004, 08:01 PM
north019 north019 is offline
?Pictures?
Anyone have pictures they can post
I have a 98 GTP waiting for Platinums
Old 05-19-2004, 09:04 AM
i3o2Matt's Avatar
i3o2Matt i3o2Matt is offline
Send a message via AIM to i3o2Matt Send a message via Yahoo to i3o2Matt
they have a special tool for pullin engine's forward...you take out the bones out n screw the tool into place, then tighten the tool n it pulls the engine forward...it looks like a V with a screw more towards the connecting point...or you could do wat the other guys said to do
Old 05-19-2004, 09:06 AM
i3o2Matt's Avatar
o and after you take out the bones, the engine doesn't move at all by itself....you need to move it yourself...i kno this because i had my plugs changed n i was standin right there (i HAD a 92 LE...it dead tho) good luck
Old 05-26-2004, 06:42 AM
oncedesired oncedesired is offline
Send a message via Yahoo to oncedesired
That dude's correct. Look online for a GM Engine Pulling Tool. You can pick one up for about $30. It's a Godsend when changing plugs. Make sure to check if your year car needs it to come with the adapter.
Old 05-28-2004, 07:55 PM
FCPorto FCPorto is offline
Post Is Car in Park or Neutral
When the doing the pushing technique after loosening the engine mount bolts, is the car supposed to be in Neutral? I know it might sound like a dumb question but sometimes there is some play even when in park. Thanks.
Old 05-28-2004, 08:22 PM
Ripn12s's Avatar
No, if its in neutral the car is going to move and keep moving until you stop pushing.
Old 05-29-2004, 08:01 AM
That's what I thought. Thanks alot for the reply.
Old 05-30-2004, 10:59 PM
s_jo4 s_jo4 is offline
does it really save time going through all that trouble to move the block maybe a couple of inches versus using some plyers and a 2 foot screwdriver to pry the plugs off? changes in 20 minutes tops.
Old 05-30-2004, 11:45 PM
Ripn12s's Avatar
I just did a set of plugs for a guy the other day. W/ the motor rocked forward I can reach all 3 in the back w/ no trouble. #6 can be a bitch becuase the O2 sensor is right in its way.
I'd say well worth the trouble, and really it is no trouble at all. 2 bolts and rock the car.
Old 05-31-2004, 10:33 PM
kilroypr's Avatar
Yah, is a lot quicker than doing the map to get to number 6 without rocking the car.
