Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 12-07-2010, 05:06 PM
Grantg82 Grantg82 is offline
99 Jimmy 4x4 problem
I just bought a 99 jimmy and the 4x4 doesn't work. All the switch lights flash on then off real quick when you turn the key on. Other than that none of the buttons even light up so i have know ideal if its in 4wd or 2wd or auto 4. Any ideas would be greatly appretiated. Thanks
Old 12-08-2010, 04:54 PM
fnawesome fnawesome is offline
Re: 99 Jimmy 4x4 problem
My 2000 had a similar problem. My switch would work when it felt like it. I tried a new switch first (didn't fix). I wound up replacing the TCM. The connection to the TCM can get corroded as well (worth checking).
Old 12-08-2010, 06:17 PM
When you replaced the tccm did that do the trick? I just checked the tccm today and it looks clean no broken wires or corosion but i found one for sale for 60 bucks so i think ill by it just to give it a try.
Old 12-08-2010, 06:40 PM
Yep, the new tccm solved the problem for me. I remember my connector being corroded and even had a wire that pulled out of the plug. But even after fixing up the plug the old tccm didn't work right. Good luck!
Jimmy 4x4 conversion rglsaenz Jimmy 1 07-21-2010 06:52 PM
Selling or Parting 93 jimmy 4x4 4.3 Votec(w) ibceng Classifieds 1 10-08-2009 04:34 PM
87 jimmy 4X4 problem todmar Jimmy 5 01-27-2005 04:31 AM
'97 Jimmy 4x4 problem chandust Jimmy 0 12-27-2004 12:06 PM
2000 jimmy 4x4 problems chaser1343113 Jimmy 1 09-16-2004 02:20 PM
