Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-17-2005, 01:14 PM
todmar todmar is offline
87 jimmy 4X4 problem
When I switch to 4 low or high the light comes on indicating that it is in that gear but i am still in rear wheel drive only??. Usually on the indicator it will light up the two front wheels showing that i am in 4 wheel drive but the only thing that lights up is the indicator next to 4 low or 4 high??
Old 01-17-2005, 03:27 PM
96JimmySLE 96JimmySLE is offline
I had the same problem on my '91. It's the vacume switch on the transfer case(or around the area I don't remember exactly) It locks in the front differential. It's common on Jimmys/Blazers. Hope this helps
Old 01-18-2005, 12:02 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 87 jimmy 4X4 problem
Yip, vacuum module under the battery tray.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-26-2005, 07:07 AM
MyOldJimmy MyOldJimmy is offline
a free and quick tip. If you can't diagnose the vacuum leack, reset your computer by disconnecting the battery +lead for about an hour or so.
Old 01-26-2005, 12:56 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: 87 jimmy 4X4 problem
His is vacuum based so that shouldn't work as well as with the electronic 4x4 systems on newer models.
Old 01-27-2005, 03:31 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Resetting the computer on a manual floor shift has no effect on the 4x4.
