Old 12-06-2010, 12:00 AM
Zlong18 Zlong18 is offline
Ignition Switch Problem, Key Stuck.
I have a 2001 Grand Am, automatic. I was having problems with not being able to turn my car completely off. It would be stuck on A/C, but i could still pull the key out, and my battery would drain. I replaced the ignition cylinder, however, even with the new cylinder, I cannot turn my car completely off, and I cannot remove the key now either. Any advice would be helpful.
Old 12-06-2010, 12:18 AM
thephantom1492 thephantom1492 is offline
Re: Ignition Switch Problem, Key Stuck.
there is a protection that if you forget to put your car into park that prevent you from removing your key. I guess that solenoid is stuck or the switch that tell that you are in park is defect... I'ld start by the solenoid first, which I have no idea where it is... or maybe it's a cable too...
Old 01-04-2011, 10:56 AM
brocsbar brocsbar is offline
the switch is by the shifter in the middle console area
95 civic EX brake light problem neosky5k '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 02-07-2011 02:30 PM
2003 z-71 4x4 switch, any way to test? TPyles Silverado 4 12-12-2010 09:34 AM
Smells like gas? Darkhog Impreza/9-2x/Outback Sport 3 12-05-2010 11:13 PM
Probe won't start Barudar Probe 1 12-05-2010 07:54 PM
Venture common problems MegaMiles Venture 2 12-05-2010 04:05 PM
