Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 12-05-2010, 07:08 PM
Darkhog Darkhog is offline
Smells like gas?
Hello!
I have a 2002 Subaru WRX sedan. A few weeks ago it got really cold and snowed here, below freezing, which isn't usual for my area. The car handles like a champ in snow, so no problems there.
I spent a few hours sledding with my son, and when I was leaving I started smelling gas.
I had the heat on and pulling air from the outside. The vents were pumping in gas fumes. When I turned the vents to recycled air, the gas smell wasn't increasing - it was only on external air. I thought it might be the car ahead of me, but when I arrived home the car still smelled gassy. Raw gas, not exhaust. A quick test drive showed that again setting to external smelled like gas.
I checked under the hood and saw no visible leaks. A quick inspection under the car revealed no dripping fluids.
The gas smell cleared out and everything is working normally now, but I still think something went wrong and I'd like to know if I'm sitting on a potential problem. I just filled my gas tank, and it is one of the lowest MPGs that I've gotten (just under 19, I'm used to about 20-22).
Anyone have any ideas what might have happened?
Thanks!
Old 12-05-2010, 07:47 PM
danielsatur danielsatur is offline
Re: Smells like gas?
How many miles are on your car?
Do they use mix Ethanol in your unleaded fuel?
If there's a problem with your car a Check Engine Light (CEL) will indicate, there's a problem.
It was cold, so your car was probably running a little rich until warm.
Depending on miles,if 100k+ you might need a good tune-up.
Air filter
fuel filter
plugs
wires
upstream H02 sensors.
Old 12-05-2010, 11:04 PM
Thanks for the reply Daniel.
The first owner of the car took really good care of it and rarely drove it. It has 36,000 miles on it. I use premium fuel, but I don't know the ethanol content. The CEL was not on.
I'm not sure exactly what that would smell like, but I don't think it was just running a little rich. This wasn't just a hint of gas. This was a full on raw gas smell, as if I had just spilled a cup of gas. I had to roll the windows down.
Old 12-05-2010, 11:13 PM
Do a visual inspect on injector seals, and fuel pressure regulator.
If there is real problem, it might take a little time to throw a DTC.
Envoy is "chugging" and smells like gas RonK99 Envoy 2 08-04-2010 01:24 AM
Smells like gas in the oil. JimWest80 Bonneville 1 07-22-2004 12:28 PM
94 Firebird Cab Smells Like GAS (I can't breathe in there) rxi115 Camaro Discussions 4 01-03-2004 07:04 PM
Car smells like gas jafowler49 Camaro Discussions 5 09-27-2003 01:46 PM
Exhaust smells like gas hondaman-iac Engineering/ Technical 8 04-14-2003 11:32 AM
Tags
gas , impreza , problem , subaru , wrx
