Old 12-05-2010, 04:21 PM
ls2002 ls2002 is offline
96 k1500 eng change CEL with codes
I just replace the 5.7 ltr eng in my daughters truck with one from a 98 Tahoe. Have taken it to Autozone, Orielly and a local trans shop. All three place gave the same codes.
1. P1810
2. P0340
3. P0102
4. P0441
Is there a common link between any or all, where should i start and which one should I start with.
Thanks
Old 12-05-2010, 05:28 PM
old_master's Avatar
Advisor/Moderator
Re: 96 k1500 eng change CEL with codes
P1810... Make sure MAP sensor is connected.
P0340... Make sure Camshaft position sensor is connected.
P0102... Make sure Mass Air Flow sensor is connected.
P0441... Make sure canister purge solenoid is connected.
Make sure the pink wire at all of those sensors has battery voltage when the ignition is in the RUN position.
You have to know how it works,
to figure out why it doesn't.
Old 12-05-2010, 07:54 PM
777stickman 777stickman is offline
Todays engine swaps require more than just nuts & bolts. Way to many electronics and changes from '96 to '98. I agree with the old master that circuits need to be checked. And all ground hook-ups.
Since this is a different CKP (CranK Position sensor) the CKP variation relearn should be done. This requires a high end scan tool.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-05-2010, 08:15 PM
danielsatur danielsatur is offline
What about the ECU/CPU software going from 1996 to 1998 motor?
Doe's your computer need a reflash?
How about Engine ground to fire wall?
Check, clean, and use a little dielectric grease on MAF sensor conn , Cam sensor conn, Evap solenoid conn.
Also check fuse + relays!
DTC P1810 - TFP valve ''Transmission Fluid Pressure Valve''
need help!!! with my k1500 Deviousk1500 C/K 1 05-16-2010 10:23 AM
Just Changed Engine need help with codes. ChrisBa Neon | Plymouth Neon 2 10-25-2009 11:02 PM
Just Changed Engine need help with codes. ChrisBa 2nd Gen 00-05 0 09-09-2009 10:15 PM
CEL with PO420 code macol Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 6 12-09-2004 03:51 PM
I got a CEL with code 1404 after cleaning out the EGR Valve fastrails Rodeo | Passport | MU 7 03-10-2004 05:46 PM
