Old 12-03-2010, 11:44 PM
702VegasLife's Avatar
702VegasLife 702VegasLife is offline
02 escort overheating
My 2002 escort just started overheating tonight on the way home from my girlfriends mom's house. It wasn't until i was parking i noticed the car was sitting higher than it normally does. Any suggestions ? Any help is much appreciated. Thanks in advance
Old 12-03-2010, 11:48 PM
Re: 02 escort overheating
Only thing recently done was an oil change, car only has 75 k miles
Old 12-04-2010, 07:49 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Don't go to your girlfriend's mom's house.
When it overheated did the cooling fan come on?
Have you checked the coolant in the radiator? (The reservoir might be full but the actual radiator low.)
I don't think the height of the car has anything to do with this.
Nevada Tumbleweed
Old 12-05-2010, 05:00 PM
Fan does come on, and i meant when i noticed the temp gauge sitting higher than normal, sorry should have been more specific haha, I tried to burp the cooling system and noticed i was loosing coolant, Now the search for the leak is on
Old 12-05-2010, 06:32 PM
couldn't find the leak... and car sat at normal temp, the whole time. But now there's water coming out of the exhaust... which i think is what i thought was leaking underneath the car... just moisture. Nor did the fan turn on this time.. but the car didn't overheat? The bushings on the fan that the coolant runs through was slowly bubbling out. Any ideas or suggestions is greatly appreciated
Old 12-06-2010, 06:23 AM
Not sure what this means "The bushings on the fan that the coolant runs through was slowly bubbling out"
It is normal to have some condensation in the exhaust. When the engine warms up the fan comes on. Sounds pretty normal to me.
Nevada Tumbleweed
Old 12-06-2010, 09:04 AM
zzyzzx2 zzyzzx2 is offline
If it still has the original water pump it might be time to change it. Check to see if it's leaking. Check for a thermostat that's stuck closed (or mostly closed).
Old 12-06-2010, 01:50 PM
Yes... It still has the original waterpump in it..
When it did cool down and i checked it last night it and it had coolant in the reservoir but did not have it in the raidiater...
Old 12-06-2010, 02:06 PM
danielsatur danielsatur is offline
Turn the HEAT on the climate control, so the internal fan will help cool the engine.
Are you getting HEAT?
Is the Temp going down?
With the Air-cond on cool Max, both electric fans should work.
I just replaced two electric fans on a 2000 taurus, because of over Heating.
$22 + $2 cover charge for both fans @ LkQx
Old 12-06-2010, 02:13 PM
Yes i am getting heat.. i had it on the whole time i drove to work today. Car also did not overheat this time. Haven't tried the a/c yet.. just the heat. I'll have to check it on my lunch
Old 12-06-2010, 02:18 PM
This time of year, the fan for the heater core is probably enough to keep the
engine temp down.
If Fans are bad, need to check fuses, and relays 1st.
You can bench test the fans with 12vdc.
I took a 12vdc jump start box to Lkqx, when looking for fans.
Old 12-06-2010, 03:06 PM
how would you check the relays?
Old 12-06-2010, 05:59 PM
Need to figure out now where the coolant leaked from that was missing from the radiator.
What part of Vegas do you live in? I used to live at Trop and Maryland Parkway. I'm up in Beatty, Nevada now.
Nevada Tumbleweed
Old 12-06-2010, 06:28 PM
If the water pump is leaking, it's time for a new timing belt too!
Old 12-06-2010, 07:12 PM
almost looks like its coming from the water pump.. and yea it is time for a new timing belt.. picking up one today actually.. it's cracked... could that be from coolant leaking onto it?
AZ tumbleweed: just moved from maryland and silverado ranch too henderson.. greenvalley and sunset.
Escort overheating. Not sure what else to do 97escortowner Escort 9 09-22-2005 12:37 AM
93 escort overheating Toro01 Escort 9 05-17-2005 12:41 AM
96 1.9L Escort overheating problem smkdamicz Escort 2 11-30-2004 08:01 PM
98 Escort Overheating Jrietzke Escort 2 10-31-2004 06:31 PM
93 ford escort overheating bgfergy General Discussion 1 10-14-2004 10:44 PM
