Old 12-03-2010, 10:00 PM
anthony90si anthony90si is offline
car starts and stalls right away
here is the deal car was sitting for a month and needed a boost! i bosted it, ran good for 15 min! i shut it off to see if it would start and it didn't! so i changed the battery. i removed the intake tube to get axces to the terminals. the air temp sensor managed to come out while doing so! i put everthing back and the car starts but does not idle! i tired many times but no luck! i am pretty sure something else must be unplugged! what can it be? sorry for the long post but its exactly what happened!!!
stock b18a1 14.97 @ 92 mph
Old 12-04-2010, 10:22 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: car starts and stalls right away
If this is a 3400 motor, Check the wires and the plug going to the IAC motor on the throttle body.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-04-2010, 04:23 PM
its a 99 with a 2.4l whats the IAC? thanks
Old 12-04-2010, 04:33 PM
Scrapper Scrapper is offline
AF Premium User
IAC is idle air control.
Old 12-04-2010, 06:54 PM
where can i find that on a 2.4?
Old 12-05-2010, 10:13 AM
tblake's Avatar
In God We Trust
On the throttle body. You may have to remove the intake ducktwork again to gain access to it.
Old 12-06-2010, 08:24 PM
thanks guys! gonna check that out when i go to the barn! but i would be surprised that it would be that! the car ran perfectly just befor i changed the battery :S
Old 12-07-2010, 11:36 AM
skeeter123 skeeter123 is offline
Check out the link below for more info on the IAC:
http://www.automotiveforums.com/vbul...d.php?t=663849
Hope this helps.
Old 12-10-2010, 05:21 PM
thank you guys! but looks liek ti has something to do with the security! its on steady!
Old 12-11-2010, 05:36 PM
AF Premium User
yes it's probably a wire running down steering colum they make wire so little it will break or could be the whole ignition cylender.
Old 12-11-2010, 08:05 PM
tblake's Avatar
In God We Trust
No you just need to do a security re-learn. I am not sure how to do it on the alero, but if its the same as the grand prix, turn the key to on not start, leave it sit for a half hour, turn it off, and back on, let it sit again for a half hour, and one more time off, and back on for a half hour. After that dont turn off, just turn to start. This may not work for alero though.
Do you have a different key you can try?
Old 12-11-2010, 08:18 PM
i did try that but for about 10-15 minuits! 3-4 times ina row! with no luck! someone told me it might be a bad car starter causing the problem!? i have no idea anymore! :S
Old 12-15-2010, 09:48 AM
tblake's Avatar
In God We Trust
Is the security light lit on the dash when you start the car?
2001 Beetle Starts and dies right away need help? yesitsme11 Beetle - New/New Beetle Convertible 4 09-18-2008 02:02 PM
98 Accord starts, then stalls right away and won't restart rummermail Accord/TSX/Accord Hybrid 3 07-09-2007 08:02 AM
88 camaro with 305 tbi starts but stalls right away camarocrazy17 F-Body Problem Diagnosis 1 05-30-2007 10:58 AM
car starts and stalls! juki_gt Grand AM 2 03-13-2005 03:23 PM
2002 SC2. Car Starts and Stalls... BGold89 SC/SL/SW 1 12-13-2004 12:01 AM
