Old 12-03-2010, 02:23 PM
loumarkd loumarkd is offline
Oil on plug 1
I just purchased an 88 4 door civic with 134k.
But my question is. I was doing a tune up on it yesterday(new plugs) and found that my plug in cyl 1 was about covered in oil. it was even up some of the threads.
Anyone else have this problem? is it just the piston ring? Car still runs great. a little sluggish when cold but once warmed runs real strong.
Thanks!
Old 12-03-2010, 07:04 PM
danielsatur danielsatur is offline
Re: Oil on plug 1
1) You could do a compression test, and compare with other cylinders.
2) Try a new PCV valve.
3) Your Engine is probably ready for a in the car valve stem seal replacement.
How much oil is being used in between oil changes?
Old 12-03-2010, 07:52 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: Oil on plug 1
Was the oil on the lower part of the plug that sparks, or on the top where the plug wire connects?
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 12-04-2010, 08:33 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Oil on plug 1
He says "even up the threads" so I'm going to assume its on the bottom side.
Do a compression test on it, and if that cylinder is lower than the others, do a leak down test, it will tell you where your problem is at.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 12-04-2010, 10:04 AM
Re: Oil on plug 1
I think I am going to try the valve cover gasket and plug gaskets first. Not sure how much oil is being lost. I just purchased the car on tuesday and did an oil change and swapped the plugs on wednesday. Thanks for the info. If the gaskets and seals dont get it then I will get a compression test done.
Thanks!
Old 12-04-2010, 01:06 PM
4G4D Store's Avatar
Re: Oil on plug 1
Sounds like a good place to start. A lot of these motors haven't had those seals replaced, so it's common to see oil on the top of the plug. Let us know know if you need anything else.
2001 Accent Transmission Oil Plug location peterf99 Accent | Verna 5 06-03-2009 01:57 PM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
Oil Leak - Oil Plug? Boloughlin 5 Series 2 07-09-2004 06:06 PM
oil pan oil plug dan rossi LHS 1 06-28-2003 01:32 PM
