Old 11-30-2010, 07:08 PM
moonie527 moonie527 is offline
turn signals/brake lights
1994 Chevy 1/2 ton w/t. When pushing the brake pedal with the headlights on, the third brakelight works fine but the rear taillights/running lights shut off entirely. The turn signals flash quicker than normal at the front on whichever side you turn on. The rear turn signals flash both at the same time but very dim no matter which side you turn on. The four way flasher works fine with the exception of the rear lights being dimmer than they should be. I'm hoping for a quick and easy solution, any suggestions?
Old 12-01-2010, 09:42 AM
Bob B Bob B is offline
Re: turn signals/brake lights
[quote=moonie527;6840201]1994 Chevy 1/2 ton w/t. When pushing the brake oth at the same time but very dim no matter which side you turn on. The four
Hi,
It sounds like your truck has a bad ground on one of the rear lights.
Bob B
Old 04-14-2011, 06:58 AM
Mike2035 Mike2035 is offline
I seem to be having the same issue. When I have the brake on, and the right turn signal on the Flasher goes much faster than the left side, could that mean the bad ground could be on the right side? I checked all of the trailer harness wiring and haven't gotten to the wiring in the frame yet. Is there a relay that may control the power? I checked the fuse box in the truck and under the hood. What is the relay inside of the cab, next to the flasher fuse??
Old 04-14-2011, 09:38 AM
Scrapper Scrapper is offline
AF Premium User
are you talking about flashers inside you have 2 of them one for emergencie lites one for turn signals?
Old 04-15-2011, 11:40 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If the right tail light flashes but is dim, check the connectors to the right side plug for corrosion. They may be oxidized or not contacting the pins to the circuit board. Give the female connectors a gentle crimp to make them "bite" onto the male pins and restore the electrical connection. Then, add some dielectric grease into the connector and around the rubber seal to keep out water and dirt.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-17-2011, 06:29 PM
Thanks I'll try that in the morning.
I happened to get into my truck and the ignition was off pressed the brake pedal. The buzzer started to go off as if I had left the lights on. Any thoughts?
Old 04-17-2011, 07:02 PM
brcidd's Avatar
brcidd brcidd is offline
This is typical of a crossed up hot wires-- the brake/turn light circuit is crossed up with the park lamp circuit. Such that either "on" feeds both.
This usually happens when the wrong bulb is inserted, or the correct bulb is not installed correctly.
But the last time I saw this, I found the conduit that houses both circuitry wires (green and brown) was smashed in behind the fuel tank support bracket- from a recent fuel pump change. The "ace" mechanic had tightened the bracket with conduit pinched between bracket and frame rail- those wires were flatter than a pankcake- and had crossed into each other- casing this nightmare.....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Turn Signals / Brake Lights / Flashers won't work paramedic71 Crown Victoria 10 02-20-2006 04:23 PM
96 Lumina turn signals/brake lights VG Groll Lumina 6 11-06-2004 02:41 PM
2000 Ranger Turn signal/Brake light/hazard light problem geminidustin Ranger | Courier 3 10-31-2004 05:47 AM
Turn signal/Brake light puzzle ABGraves Rodeo | Passport | MU 5 08-03-2004 09:46 AM
turn signal, brake light stays on bevomar Windstar 0 04-19-2004 01:34 PM
