Go Back   Automotive Forums Car Chat > Buick > Electra
Old 11-30-2010, 11:02 AM
wolfsburg78 wolfsburg78 is offline
Question Shaking the bolts loose
I have an 89 Electra Park Avenue with 230,000 miles. I got the car after my mother in law passed away in October. I recently replaced the EGR valve, coil, fuel pressure regulator, PCV valve, intake manifold gasket and added seafoam to the gas tank. The plugs and wires were replaced about two years ago along with the fuel filter. It will run fine most of the time but sometimes will suddenly start to run very rough and shake hard if I try to give it more gas and will idle rough after this. It will do this at any speed with no warning. I do notice the RPM’s drop just before it starts to shake as if the transmission has shifted gears. It also seems to run fast; that is it will almost maintain speed without even touching the gas. I have to keep my foot on the brake going up my street to keep from going too fast. Any help would be appreciated.
Old 12-02-2010, 11:20 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Shaking the bolts loose
You may have an Idle Air Control (IAC) problem, or vacuum leak. You can remove the IAC & try cleaning the pintle & seat with carb cleaner. In addition, check TPS & verify voltage @ closed throttle & WOT. It is easier to use a scanner for this purpose, but the wires can be probed for voltage, if you don't have one.
steering wheel shaking, pulling to the right uspres2020 Escort 6 10-10-2009 06:58 PM
Intake bolts loose on 3.4 ???? jesuslover Venture 2 11-27-2006 11:30 PM
Wobble Wobble Shake Shake Down The Road I Go brittce Taurus | Taurus Wagon 9 03-23-2005 07:51 AM
Hub Bolt Loose? blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 10-15-2003 04:56 PM
Is the 350z wheel bolt pattern the same as 300z 2003350zgirl Nissan 350Z/370Z | Infiniti G35/G37 Coupe 5 10-12-2002 04:16 AM
