Old 03-21-2005, 11:00 AM
brittce brittce is offline
Angry Wobble Wobble Shake Shake Down The Road I Go
Here's another problem I have with my 97 Ford Taurus GL Stationwagon,
When I'm going between 60 and 75 my car starts to severely wobble and shake as if the tires are about to come off, This past Saturday I change front brake pads and got a brand new Tire for the Driver's side I also notice the tech tightening the Lock nut on that side. could this be a problem as well on the other side and should I have it check to.
Old 03-21-2005, 11:09 AM
hughw hughw is offline
Check the lug nots...if thats not the problem..There may be a
bubble on one of the tires...jack it up and use a coke can ...
hold it close to the tire...turn the tire and see if it hits the coke can at any point.
Old 03-21-2005, 01:49 PM
Re: Wobble Wobble Shake Shake Down The Road I Go
I'll try that this evening when I get home thanks
Old 03-21-2005, 01:52 PM
sfontain sfontain is offline
Re: Re: Wobble Wobble Shake Shake Down The Road I Go
Did I understand you correctly that you said you got a single new tire?
If that's the case, then if the other tire on that axle is not new or is a different brand and/or size, that can cause significant driveability problems too.
Old 03-21-2005, 01:59 PM
Both tires are new the one on the passenger side is about three weeks older and both tires are the same Uniroyal Tires.
Old 03-21-2005, 02:04 PM
Ok that shouldn't be the problem then. Also make sure they are inflated to the same pressure. Good luck!
Old 03-22-2005, 12:34 AM
Wodinator Wodinator is offline
perhaps one of the weighted balancers fell off???
Old 03-22-2005, 03:23 PM
GPFred GPFred is offline
Sounds like a tire out of balance to me too. The other possibility is a tie-rod end could be going bad if there is jerking in the steering at 60-75 mph. Does it stop when you go past 75mph?
Old 03-22-2005, 04:36 PM
YES it stops after I reach 75 that's exactly the problem
Old 03-23-2005, 06:51 AM
I would look at tie-rod ends then. If it is wobbling the steering, I would have a suspension shop look at your front end.
