Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 11-28-2010, 08:22 PM
LieutenantCracker's Avatar
LieutenantCracker LieutenantCracker is offline
Window won't go down/won't go up
'96 Town Car, Signature Series.
I took the door panel off and can seen that the cable is frayed. Seems obvious that it's getting stuck in the track or a pulley or something.
It WILL go up and down about 4-5 inches in either direction, so I'm pretty sure the motor is still fine(?)
So, replacing the cable seems to be the obvious answer but, there's no freakin' room to work inside the door! How is one supposed to replace said cable? I can't even get my hand in there well enough to feel either end of the cable, and I have pretty skinny hands-- let alone being able to even see what's going on in there!
________
Synthetic weed
Old 11-28-2010, 10:40 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Window won't go down/won't go up
It is common for the cable to wear out with age. You should replace the whole window regulator assembly, AFAIK there is no official replacement for the cable, my brother tried to replace it and he ended up replacing the whole regulator because the cable kept braking at the ends of it.
To remove it you have to drill out the 3 1/4" rivets holding it to the door. Since you'll be removing the regulator and the motor, it would be a good idea to replace the motor nylon bushings too, these can be bought at any autoparts store like autozone, advance auto, etc. Look for a red blister and HELP! brand.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 11-30-2010, 09:32 PM
mrd2001 mrd2001 is offline
I just replace all four on my 96 TC. got them on line about $20-25 each. I only needed two of them but replaced them all anyway. Also replaced the gears in the motors while you have them apart. Autozone $20 each. They should last for years without any more trouble.
Old 01-01-2011, 06:40 PM
half-fast half-fast is offline
Where did you get the regulators?
Old 01-01-2011, 07:52 PM
danielsatur danielsatur is offline
I buy mine on Ebay!
Caution - Always make sure your window is all the way up, or down when shutting the door. The cable will bounce around and bind up the window regulator.
The next time you use the electric window, it will break.
96 Passat GLS windows rolling down in rain RJuntunen '93 - '96 0 09-08-2010 12:00 AM
2004 Sebring LXi, 2.7, passenger window goes down only...? miki75 Sebring | Sebring Coupe | Convertible 5 04-05-2010 08:57 AM
98 power window express down problem fliplover Monte Carlo 1 04-03-2009 11:48 AM
window clicks but won't go down pleadwell Silverado 7 06-26-2006 07:34 AM
1994 Civic EX window rolled down and won't go up!!! taytay077 Let's get Technical! 1 09-18-2004 02:48 PM
