Old 06-22-2006, 04:18 AM
pleadwell pleadwell is offline
window clicks but won't go down
Hello folks,
Anyone have any idea on why a specfic window in my truck won't go down. All my windows work with the exception of the passenger window - it just makes a clicking noise when you press either the driver's button to engage it or the button on its door. It did this a couple of times before but just started working again almost right away but now its been a couple of weeks and its driving me nuts ---any suggestions or help?
Derek
Old 06-22-2006, 06:27 AM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
Re: window clicks but won't go down
Could be a broken gear or something coming loose, causing the attachment to the motor to not make sufficient contact.
Only way to know for sure is to take it apart. Doesn't take but a minute to get the doorpanel off.
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 06-22-2006, 08:37 AM
thanks for the response ...what's the easiest way to get the panel off? I took off the window button panel already ...does anyone know a link to show it?
It's getting hot out there and the wife hates AC :-)
Old 06-22-2006, 11:33 AM
Its been about a year since I've fooled with it, I think there are 7mm hex screws at the base of the door panel, and just underneath the armrest. I think there is a third somewhere. I'm not sure if you have to remove the triangular trim piece by the window or not, if you do it just pulls directly off.
Once you have all of the hex screws out, lift the doorpanel directly up a few inches and pull away from the door. I'll take a look at my truck after work and see if I can remember better =).
Old 06-22-2006, 01:34 PM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
Could be the motor's bad and you are hearing the relay click? Yes, you should pull the door panel off and check it out. It would help to know the year. On my '02 I think I had to pull the map pocket out prior to removing the panel.
'02 2500HD 6.0/4.10 Air Lift bags, 175 psi onboard air
Old 06-22-2006, 04:02 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
there are 2 screws below armrest and sometimes 1 behind lock lever. then pop off mirror cover on inside and unplug and remove all switch panels. then lift door panel off and unplug domelight in door and set aside panel. should be very easy once all screws are out the door panel will slide straight up farily easy.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 06-23-2006, 05:54 AM
Thanks folks, I'm going to give this a try this weke-end - as for year its a 2001 Z71 Tahoe and I love it :-)
Old 06-26-2006, 07:34 AM
intel_guy intel_guy is offline
I had the same thing last week. I did mine (for the first time) over the weekend and it was about a 1/2 hour job. The second screw is behind the pop-off window/lock controls.
