Old 11-28-2010, 01:33 PM
jcinkc jcinkc is offline
no gas
blew seal in transmission about three months ago and i could'nt get time to fix it right away so it sat for three months. I went to start it and battery was dead jumped it and it would not start. took off fuel filter and its not pumping gas. any ideas
Old 11-28-2010, 01:46 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: no gas
Check fuel pump relay and connections at engine compartment, swap it with any other. If it doesn't helps you might have a bad fuel pump.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 11-28-2010, 01:55 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: no gas
Do you hear the fuel pump prime when key is ON with the jump-start battery? I wonder why the fuel pump would stop working after sitting for long time, but it's the first thing to check. Remove also big fuel pump's fuse and plug an 10 Amp amperemeter at fuse socket when key is to ON. It will tell you if the pump is shorted, opened or maybe bad wiring/contact/relay/safety switch... If no current, check also your fuel pump safety switch.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 11-28-2010, 05:52 PM
12Ounce 12Ounce is offline
Re: no gas
What model year and engine?
Old 11-28-2010, 09:23 PM
Re: no gas
Maybe the old fuel clogs the inlet filter screen of the fuel pump so it can't pump. You can pour all the fuel in a plastic gas reservoir if you have, and put fresh fuel in your tank. And try if it works.
Old 11-28-2010, 10:28 PM
tempfixit tempfixit is offline
Re: no gas
Try tapping on the gas tank with a rubber mallet or 2x4, maybe it will knock any setiment off the pick up screen or jarr the fuel pump free from binding.
Old 11-29-2010, 06:49 AM
Re: no gas
its a 2002 3.8. i switched the relays and fuse looks good. i think ill remove tranny first to see if its still good then decide on fuel pump thanks
Gas Odour / Gas Tank Replacement bigaldover Blazer 2 05-22-2005 02:29 PM
96 Maxima SE Repair Advice Cont. (Bad Gas Mil. and Sticky gas pedal) sixninjas Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 05-23-2004 09:41 PM
tokico gas shoxs vs. tokico non gas fresnogsr Integra 1 03-29-2004 02:16 AM
gas gauge is stuck half way with full tank of gas jerom 3 Series 3 07-14-2003 07:50 PM
what mods save gas and what mods waste gas? asnrefugee '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 03-21-2002 12:00 PM
