Old 11-28-2010, 03:43 AM
12gaugeCharlee 12gaugeCharlee is offline
Need Help with a weird problem
Okay so here is whats going on when I go and start my 96 grand voyager in the morning I goto put it into revers it backs up for a few feet then just stops moving. Then I goto put it into drive it dose nothing until I give it some gas then it engages and starts going but then after about a mile or so it'll do it again. But here is the weird part if I let the engine warm up it works like there is nothing wrong. It started this problem after we had some cold weather where the temps got into the low teens. Any ideas will be appreciated.
Old 11-28-2010, 04:17 AM
mikefaster mikefaster is offline
Re: Need Help with a weird problem
Change the fluid and filter... Use only atf+4 fluid and more importantly a new filter to boost pressure......
The ATF+4 fluid is full synthetic and will help condition the seals as well (also help increase pressure)...
Mike
Old 11-28-2010, 04:22 AM
Also, this requires removal of the valve body, but if it persists, you probably have a low/reverse accumulator ring and/or the low/reverse accumulator cover seal that is wearing out... I have changed them before on the car with much success... I have installed an updated low/reverse accumulator cover (with built in lip seal) that is on all of those transmissions from 2004 and up... It also pays changing all the accumulator rings for all 4 accumulators when you're in there...
I may not be able to help for a week again, because I am going to California (driving there)...
Hope that helps...
Mike
Old 11-28-2010, 04:34 AM
Thanks for the info mikefaster I guess I frogot to mention that we had the trany rebuilt about a year ago not sure if this has any bearing on the problem.
Old 11-28-2010, 06:38 AM
I'm leaving as we speak, but, you're lucky if anyone does anything "the right way" anymore, anyway... It may just need a tranny tune up; fluid and filter...
Old 11-28-2010, 03:59 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Agreed. First step in just about any tranny issue next to checking fluid level is to change the fluid and filter. Gives you a chance to check for debrie in the pan. Anything more than fuzz on the magnets warrants at least a look by the pros and a probable rebuild.
mikefaster - be safe on that l l l o o o n n n g g g trip.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 12-01-2010, 01:21 AM
58 hours and about 5 hours of sleep... I'm surely not as chipper as I was when I drive to Los Angeles 5 years ago... Gettin' old at 36, lol...
Find anything in the pan?
Old 12-04-2010, 10:56 PM
Thank you guys for the help I was the fluid level being low topped it up and it shifts like a new trany.
Need help with a problem sandy809 Camaro Discussions 6 03-15-2004 09:31 PM
Need Help With Starting Problem!!! paintbb84 Golf 1 02-25-2004 05:14 PM
need help with cooling problem wolffe Maintenance 1 02-04-2004 09:57 AM
Need help with my problem!!! DiabloFan F1 7 10-21-2003 12:38 PM
Need Help With Engine Problem!!!! worrdogg '88 - '91 Civic | CRX | Wagon | Shuttlee 1 11-16-2002 03:26 AM
