Old 11-16-2002, 03:13 AM
worrdogg worrdogg is offline
Unhappy Need Help With Engine Problem!!!!
I just did a JDM B16A swap in my 89 Civic sedan and ran into a problem. Here goes - When I drive around all day the engine runs fine but when I drive home from town on the highway at about 60mph the engine lags, and during the lag when I press the gas pedal nothing happens all it does is open the throttle and I can hear it but it the engine will not rev any higher. Now when I put it in neutral (still on the highway rolling at about 50mph) the engine shuts off. I then pull on the side of the highway and try to start it but it wont start. But when I wait a minute or so and try again it starts up and I drive off for about 10-15 minutes and it starts doing it again, and this keeps happening over and over. But here’s the funny thing, sometimes when the engine lags, I keep pressing the gas pedal and sometimes the engine kicks in and I can drive off till the next engine lag. What the heck is wrong? PLEASE ANYONE HELP!!!!!!!!!!!!
Old 11-16-2002, 03:26 AM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
Have you removed your distributor cap and looked in there yet? Sometimes that screw that holds the rotor on backs out a little. My car was bogging for a while, before it completely backed out, and the rotor gyrated on the shaft, causing my ignition timing to be really really off. Then the motor died. This probably isn't it, but it's worth a look
oh, and also the JDM first gen (non-OBD) B16A distributors are known to crap out easily (usually the bearing seazes, which is what happened to me). You might try removing the distributor completely, and spinning the thing that plugs into the end of the intake cam. It should spin easily, with little resistance. hope this helped some time to go to bed...
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Need Help with engine light, sensor problem dtrixny Quest | Presage | Serena 8 08-14-2008 05:54 AM
2002 Accord 4 CYL New Owner Needs Help with Engine Problem (Stalling and Maint. Light ncpmedic Accord/TSX/Accord Hybrid 4 10-18-2005 05:35 PM
2002 Accord 4 CYL New Owner Needs Help with Engine Problem (Stalling and Maint. Light ncpmedic Let's get Technical! 1 10-17-2005 12:46 PM
need help with engine problem emopunksucksnuts Engineering/ Technical 2 10-19-2004 03:15 PM
need help with engine light problem drewk420 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 04-15-2004 05:34 PM
